Old 12-05-2015, 06:31 AM   #1
Artist, 986S tinkerer
NewArt's Avatar
Glass window and service mode?
I'm tempted by the glass windowed top. I do all my own maintenance and mechanics. So, a question to those of you who have done the top replacement: how does this affect the service mode access to the top of the motor? Does anyone have a picture of this?
Old 12-05-2015, 06:35 AM   #2
Well this topic has certainly never been covered before.
'99 black 986
Old 12-05-2015, 07:31 AM   #3
NewArt's Avatar
Well gee Mark, thanks for that. I just pushed that button and up popped a picture of a Boxster with an aftermarket glass windowed top placed in service mode showing the sort of engine access one might expect. Not.
I'll remember this in the future.
Old 12-05-2015, 07:57 AM   #4
98 Arctic silver 986
tommy583's Avatar
I have an aftermarket glass window top. The access is a little less than with the plastic window top. With that being said the improvement with the glass top far out ways the limited engine access. With the glass window I was easily able to remove the throttle body, change air filter and clean the MAF. There really isn't that much stuff that need to be done from the top of the engine in my experience. The glass window top is so worth it. It makes the car look brand new and no more Boxster chop.
Old 12-05-2015, 03:02 PM   #5
NewArt's Avatar
Hey, thanks for the observations Tommy. Next time you're in there, try to snap a pic. I've not yet found one (even using the magic button )
Old 12-05-2015, 03:28 PM   #6
I am my own mechanic....
Timco's Avatar
I put the top about 3 inches from the windshield. Then I use a bungee to pull the glass area up higher. The two snaps pop off of course.
Then the clamshell sits in a service position by popping the clips off and putting a screwdriver in the holes when they line up. Keeps it up high.
Use a paint stir stick under that bungee so it doesn't grab the seal under the back window.
That's the best I've been able to do.
'08 VW Touareg T-3 wife's car
Old 12-05-2015, 03:33 PM   #7
07 Carrera S Cab
Boxtaboy's Avatar
I found this link in the search function by typing in (glass top service position)... It has pics of the top in service position on a Boxster with an aftermarket glass top.
http://986forum.com/forums/general-discussions/34311-engine-access-gahh-top.html
Old 12-05-2015, 04:19 PM   #8
NewArt's Avatar
And thank you for that! I hadn't seen these photos and I must say that it does seem to cause a significant restriction.
Old 12-05-2015, 04:22 PM   #9
NewArt's Avatar
So, does your window move up, out of the way, as opposed to the images in the link posted by Boxtaboy?
Old 12-05-2015, 05:45 PM   #10
tommy583's Avatar
I use a bungee cord from the front of the top to the back. I think I get at least a few more inches than the pic in the other thread shows. I would take a pic for you but my car is all buttoned up for the winter.
Old 12-05-2015, 08:09 PM   #11
Timco's Avatar
No. The window kind of sits as pictured but with the clam shell in service position using those holes you do get better access. The bungee from windshield to the bottom edge under the window does pull it up farther it looks like.
Old 12-05-2015, 10:16 PM   #12
njbray's Avatar
I went and split my window the other day - it was cold and I did the chop but it split on one edge (when I say cold, around 60! hey I did have to put on a sweater!).
Anywhooo, I am now looking at a glass window top replacement soon.
I have been thinking about access and figure I only go in from the top to check steering fluid and air cleaner. All the other stuff, oil filter/change, spark plugs, drive belt, etc. is got at from below or behind seats! So I can't think of a reason not to go glass window!
Old 12-06-2015, 04:25 PM   #13
How many times/year do you have to access the top of your of your engine and for what? I put a glass windowed top on my car last summer. I've accessed the top of my motor twice, during oil changes, when I cleaned my air filter and MAF sensor. Access is more than enough to perform these simple tasks.
Using the bungee does really help.
My thinking is that if I was needing to perform a task that required extended access, I would take a half an hour and remove the entire top/frame.
Old 12-06-2015, 04:52 PM   #14
NewArt's Avatar
Good point. In fact, the times when I need access to the top of the motor is when there's a major problem: vac leak, aos, etc. It's not every day. Even at the track, it's not like I was tuning carbs or something!
Old 01-15-2018, 08:30 AM   #15
Service Mode with Hardtop Installed
Can you access the top of the engine (i.e. Service Mode) with a hardtop installed? The soft top is still installed, just retracted. Anyone done it?
Porsche-Eh is offline   Reply With Quote
Old 01-15-2018, 09:43 AM   #16
1998 Boxster Silver/Red
Um... I'm going to guess no.
1998 Porsche Boxster
Old 01-15-2018, 03:33 PM   #17
A8ked's Avatar
I've got the hardtop option, it has to be removed and then the soft top has to be put into the service position to access the engine from the top.
We had a dry day here today so I just finished removing the hardtop and opening the top engine access to change the air filter and check power steering fluid.
I had a new soft top with the glass window installed in October as others have said it does limit access a little, but changing the air filter and checking the fluid was not difficult.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
