Old 12-01-2015, 06:04 AM   #1
Rebuilt water pump
Any thought on them? Worth the risk?
DWBOX2000 is offline   Reply With Quote
Old 12-01-2015, 06:26 AM   #2
no,no,no,no, and no
Woody
Old 12-01-2015, 07:07 AM   #3
If Woody says no, it's no.
Old 12-01-2015, 07:43 AM   #4
ppbon's Avatar
You have to weigh the PROS and CONS when making any decision.
The PROS: oh, there are none.
The CONS: I can't believe anyone would seriously think about it?
After analyzing the data I think the answer is NO.
Happy Boxstering
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 12-01-2015, 07:46 AM   #5
On the slippery slope
JayG's Avatar
You are joking, right?
Its a relative easy DIY
Get a Pierburg WP, they are the same as the Porsche branded ones
2004 996 Targa Tip
Instructor - San Diego region
Old 12-01-2015, 08:48 AM   #6
No joke. I didn't know the answer so I asked the question. Glad your not my teacher.
Thanks everyone. I have my answer.
Old 12-01-2015, 08:51 AM   #7
Plastic or metal propeller?
Old 12-01-2015, 09:02 AM   #8
Composite is the term(plastic). Go with the pier berg pump on pelican it's the oem manufacturer for porsche without the Porsche label.
If you search metal impeller on this forum you'll see why you don't want that metal impeller anywhere near your 20k dollar motor.
Old 12-01-2015, 09:07 AM   #9
There Is No Substitute.
rick3000's Avatar
Absolutely no. Get a Pierburg, they are Porsche OEM.
Old 12-01-2015, 09:57 AM   #10
Motorist & Coffee Drinker
78F350's Avatar
Hi DWBOX2000, I was at the USCG station in Scituate back in the early 80s. Nice little town then.
I tried to save a little money buying a water pump a year ago and bought one on Amazon. It stated that it had a plastic impeller, but when it arrived it was metal. I installed it anyway, but plan to replace it early. As all have stated: buy Pierburg/OEM with the plastic impeller.
Here's a few good threads:
Jake Raby's advice:Water Pump - Page 2 - Rennlist Discussion Forums
Discussion of aftermarket with early failures:
http://986forum.com/forums/general-discussions/55937-aftermarket-waterpump.html
A long discussion good points on both sides:
GEBA pump with metal impeller
Old 12-01-2015, 09:45 AM   #11
JayG's Avatar
Maybe if you had done a search a bit you would have found out the answer to your question about using a rebuilt WP as well as metal vs composite impeller
In any case, best deal I found for a pierburg WP is at
warehouse33auto.com
If you enter the coupon code RENNLIST at checkout you get a 10% discount
don't forget to get the gasket and you probably will need that virgin unicorn sperm Porsche calls coolant. it runs ~$40/gal and you need 5-6 gallons diluted 50/50. Might as well replace the thermostat while you are in there
I paid $190 for the WP, $52 for low temp thermo/housing/gasket & $3.50 for the WP gasket, no sales tax and free shipping. Coolant was ~$40/gal as well
2004 996 Targa Tip
Old 12-01-2015, 10:05 AM   #12
78F350's Avatar
....and for the gasket, use the coated metal style with no sealant. With these engines, gasket sealant has a tendency to squeeze out of the seal and become debris in the coolant passages.
Old 12-01-2015, 10:20 AM   #13
steved0x's Avatar
I got my 3 gallons of coolant from Suncoast and mixed with 3 gallons of distilled water, and did a low temp thermostat at the same time, and pierburg WP. There is a good article on Rennlist on how to easily bled every drop of coolant out but I think it may be 996 specific, but there may be some parts in there applicable to us:
Simple 3-step complete coolant drain (updated w/ refill procedure + water pump tips) - Rennlist Discussion Forums
It is for 996 so the hose routing and stuff may be different enough that it does not apply to us, but I thought it was pretty interesting.
Steve
Old 12-01-2015, 10:30 AM   #14
The USSG is still there. Thanks for your service. We have been in scituate for 20 years, still love it.
I'll read all this stuff tonight, thanks again everyone for the input.
Old 12-01-2015, 08:39 PM   #15
Ok, I'll be in the minority here....I bought a gates WP for $72 and installed it (with metal gasket and OEM thermostat) a year ago and immediately drove from Panama City Beach to Ft.Lauderdale and back. As easy as the DYI job was, I'll keep an eye on it and change it out again if it fails.
FWIW, my old pump did not fail at 126K miles. I could tell it was original as the original gasket was in place. After I got into the job, it looked like all that was wrong was a little weeping from one of the bolts. I replaced it anyway as I had it all apart. Upon inspection of the OEM pump there was no wobble or noise from the shaft or bearing. Given the 7ft-lb torque requirement, I'll bet I could have snugged up the bolts and been good to go!
dghii is online now   Reply With Quote
