11-14-2015, 04:00 PM
can bank 1 cam cover be removed in situe ?
Just spent the day replacing bank 2 head,
I bought another chain guide pack, plug tube seals and lifters for bank 1, looks very tight, bank 2 was bad enough.
Before I break the seal does anyone know for definate if bank 1 cam cover can be removed in situe. ?
Cheers
Barks.
11-14-2015, 06:04 PM
Originally Posted by barks
Cheers
Barks.
You can do it in the car, BUT the passenger side (Bank 1) has less room than the driver side. I usually drop the exhaust and rear tranny mounts and then lower/tilt the engine to get a bit better access (it helps).
So much easier when the whole engine is out though; and you'll definitely want to do the vario-cam tensioner pads on Bank 1 (they seem to always be worse than the ones in bank 2)...
H
Previously owned:
11-14-2015, 07:14 PM
You mean 'in situ?'
11-15-2015, 12:16 PM
Artist, 986S tinkerer
Originally Posted by Joe B
You mean 'in situ?'
Hey, give the man a brake!
11-15-2015, 01:46 PM
I am my own mechanic....
What a looser.
'08 VW Touareg T-3 wife's car
11-17-2015, 03:04 AM
Thanks h
Did it yesterday. Very tight but managed it by just unhooking and cable tied the ally pipes to the brake pipe support.
I was going to do a thread showing the head removal, camshaft replacement, variocam chain guide replacement, lifter replacement, bank 2. And lifter replacement, chain guide and rebuild bank 1 all with the engine in done off an axle stand but I won't now as I fear there may be a few spelling mistakes.
I don't write a lot these days normally java and android code,,
Barks
11-17-2015, 03:34 AM
Hey barks,
just write it down with some photos. If there are mistakes - who cares. This is a forum. It's intended to learn from each other.
Regards, Markus
11-17-2015, 05:03 AM
Thanks h
Barks
Sorry if you were insulted or your feelings were hurt; not my intention. I always appreciate knowing when I've made a mistake so I can learn from it and improve  .
09-24-2016, 09:08 PM
Thanks h
Barks
How long did it take you?
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
