Old 11-14-2015, 07:04 PM   #2
Heiko
Heiko's Avatar
Originally Posted by barks View Post
Hi,
Just spent the day replacing bank 2 head,
I bought another chain guide pack, plug tube seals and lifters for bank 1, looks very tight, bank 2 was bad enough.
Before I break the seal does anyone know for definate if bank 1 cam cover can be removed in situe. ?
Cheers
Barks.
You can do it in the car, BUT the passenger side (Bank 1) has less room than the driver side. I usually drop the exhaust and rear tranny mounts and then lower/tilt the engine to get a bit better access (it helps).
So much easier when the whole engine is out though; and you'll definitely want to do the vario-cam tensioner pads on Bank 1 (they seem to always be worse than the ones in bank 2)...
H
Previously owned:
