As a long time air cooled guy I acquired an 03 986S to dip the proverbial toe in the water. I've loved reading your posts and plan to incorporate or follow your lead on many of the things you've done. This summer I decided to track the car. (been involved with PCA Club racing and DE for 25 years with early 911 which I'm taking back to street. ) Through the process with the box, I added deep sump, baffle mod, spin on oil filter and the car had already had the dual ceramic LN upgraded IMS. Hot day, but careful with rev's and heat. Spun bearing. Much knashing of teeth and after 2 months of not finding a decent 3.2, I found a 70K 03 3.6 motor. Had the LN I'M done already. Dirty but leak free and just enough grime in the intake stacks to lead me to believe a normal motor. PO purchased entire 03 as a total front end collision. Also owns 99 996 and thought he would put this motor in until realized the challenges of cross pollination between the vastly different DME and CAN BUS. <6% (cold) leakdown. Long story short, I'm now preparing to do a swap. While I have many questions, what prompted me today was reading about your IMS puller. How do you tap only part of your thread? (Impossible circum.) We doing only 1/2 the length? (Re 8mmx1.0 vs 8mmx1.5). Other questions: Sonax tire cleaner? What happens to sensors when you delete the second set of cats? Do you weld bungs on the pipe itself? I'll be doing new clutch but waiting to see condition of flywheel. More but I'll keep them short and specific to your topics. Sent from my SAMSUNG-SM-G900A using Tapatalk |
The long coupling nut has the 1.5 (call it a coarse thread) thread all the way thru, so I just took a 1.0 ( fine thread) tap and started it on the other end and ran the new thread in. I didn't drill it or anything. Just ran it in 50% of the way to make sure it had enough thread engagement for the end of the bearing stud. If that had not worked, I would have welded 2, 1.0 nuts onto the end of the coupling nut. Yup Sonax cleaner. That stuff is the bomb for wheels and engines and transmissions. If I were to go all OCD on it (or CDO depending on how bad you have it) I would h ave pulled out the small steam cleaner to get at the small crannies cleaned out. There are no sensors for the 2nd set of cats. The new pipes have holes for sensors but they are not used. Ask away. We have air cooled in the house too! |
I live in Colorado with pretty stringent epa standards so am concerned about this car passing emissions minus second set of cats. I realize that many boxster owners live in California which has the harshest EPA standards in the country so would be interested in knowing what they do there if they delete. They also visually inspect here so without the second cats, they may ding one on the basis of the emissions control having been altered visually. However looking at this, it seems that I could reattach the old cats for the purposes of emissions and then run the straight pipes and be good to go. Out of curiosity, what part of New York state do you live? Sent from my SAMSUNG-SM-G900A using Tapatalk |
I live near Poughkeepsie, about 1/2 way between NYC and Albany. But, we have just sold our home here and will be moving to our home in MD on the eastern shore to get ready for retirement. We need to cut costs to do this early if we want.
There are cats there so unless they have a picture of the system handy, the visual might get by them. |
A weekend update!!
Work continues slowly on the multiple projects from the interior to the oil cooler. Last update was about how I had oil in the coolant :-( Very distressing to see. I pulled the cooler and pressure tested it only to find a leak from the oil side to the coolant side. I ordered a new "S" cooler which is about 2x the size of the original base cooler and once it arrived, I bolted it right in. It fits without taking any other parts off!! I like that. New Cooler: http://i70.photobucket.com/albums/i1...pscoxg4san.jpg Old bad bad bad cooler: http://i70.photobucket.com/albums/i1...psdjeaenua.jpg New cooler bolted in and not it comes to filling the cooling system and figuring out a way to get the grease and gunk out of the coolant and system. I did some interweb reading and found that the majority of folks that have this issue use dishwasher (Cascade) to mix with the water and break the oil down. We didn't have the massive milkshake level of intermix but enough to leave a fugly film on the inside of the tank and I'm sure everywhere else. I put 1/4 cup into some water, mixed it up and poured it in with my fingers crossed. I let the dishwasher wash and took the car for a drive. after 10 miles or so I got back to the garage and the coolant looked all white and disgusting. I let that sit overnight and then drained it out thru the plug in the bottom of the engine. Refilled with fresh water and took for another ride. 10 miles more and another drain and refill. Today I once again repeated the cycle with simple green in the coolant and I'm getting to the point where the stuff stays clear but there are some white oil boogers floating around that also creates a film in the tank overnight. Not sure how many flushes it will take to get the majority of the oil out. Maybe 1 -2 more i hope.... While waiting for the oil cooler to arrive, I began the install of a new stereo and that required a bit of rearranging of the center stack. I moved the climate controls down to the cubby location and then moved the CD holders up to the top where the climate controls were. I have a single DIN stereo with the fold out screen to install just below the CD holder (useless) and when the screen folds out, it will fold out and stand in front of these cd slots. I picked up a regular sized cubby from Woody to replace the CD holder in the lower portion. All of this just pops in and makes the swapping mostly painless. The wiring from the stock stereo to the new stereo will probably be a challenge. http://i70.photobucket.com/albums/i1...psyebc6uib.jpg I also pulled the rear air-dam motor and system out because no matter what I did I could not get it to work. I figured it was going to have to be replaced but decided to give it a shot to get it going. Once pulled out it was easy to get the motor connections attached to a battery to see if there was life. Nope dead as a Dodo... I began disassembling the motor from the rest of the gearings and found RUST!! It appears that water got into the gear box and jammed the 2nd stage of gearing. Once the motor was pulled out it ran just fine in each direction. I took all of the gear sets apart and found rust and old hardened grease. Once cleaned and re-greased I put it all back together only to find that I didn't have the gears "timed" properly and the 2 posts were not even heights. Take it all apart again and set the 2 gear racks the same and then put it all back together. Practice makes perfect! http://i70.photobucket.com/albums/i1...pssfirkpgw.jpg http://i70.photobucket.com/albums/i1...psho3polio.jpg I installed in onto the car but it still doesn't got up and down. With a seized motor, I figure the relays have overloaded or burned and will have to be replaced. |
I would check fuses first, than relays.
Regads, Markus |
I dropped the quest for a working spoiler and continued to pursue a proper running engine. I have been hearing a miss and once I got the Durametric knock off cable and software from China I was able to determine that #6 was showing LOTS of misses. I had already gotten a new coil in because I heard the miss and figured that a coil pack would be the culprit. Well, it was. This is the log that it can create for you:
Time-------------------------------Misfire counter cylinder 6 15:23:31.98----------------------------------11 15:23:32.48----------------------------------18 15:23:32.96----------------------------------27 15:23:33.47----------------------------------38 15:23:33.91-----------------------------------6 15:23:34.36-----------------------------------8 15:23:34.82-----------------------------------9 So changing the coil for #6 was quite easy as it's only held in place by 2 bolts, so out with the old and in with the new. The old coil has multiple cracks in it highlighted by white marker. http://i70.photobucket.com/albums/i1...psbibmek7g.jpg http://i70.photobucket.com/albums/i1...psxllx2pme.jpg http://i70.photobucket.com/albums/i1...psbpbofnzs.jpg http://i70.photobucket.com/albums/i1...pss8t04fqz.jpg These cracks allowed water to get inside and either short the coil or allow it to track to ground. I found water on the tip of the coil after pulling the rubber extension off. Next it's time to change the MAF and see where that goes. Then on to track down the )2 sensor faults... The MAF may just be the root of all this evil!! |
Wow. I'm in awe!
Changed the MAF yesterday afternoon and the car has never run better. We haven't had it that long but when started up and cold it had a flat spot and some stumbling. This is what led to the software purchase for looking at things that the computers are supposed to help with.
Install MAF and clear the codes. Drive around a bit and check for new codes. It's throwing a code for the 02 sensor on the #2 bank in front of the cat. Pull in the computer and look at the reading for the o2 sensor and see it reads zero voltage. Check the plug to make sure all is well and then install a new one. Guess what? No more o2 codes. Today wasn't all sunshine, bunnie rabbits and unicorns tho.... Fix one problem and another crops up. Water pump has decided to pack it in this morning with a nice drip, drip, drip on the drive. What God did I offend to deserve this? I just put 2 gallons of Porsche coolant and demineralization water in the beast. So, new water pump tomorrow and maybe the cooling system gremlins will finally be dead. More to do, and will try to post some pictures tomorrow to close out some projects. |
I saw on another thread you mentioned about buying some paint. Are you painting the whole car or just some parts? Please let us know how that turns out too. I'll need to paint some parts on mine and I'm very nervous about color matching.
I installed a double-din navigation unit with ipod integration in my car, but it sounds like you have a single-din unit already and I understand that you would want to control your costs. Good luck with your work. |
Big Update this weekend!!!
First of all Allie is home!!!! It's just for a few days so we can finish up a few things and she can take the car back to VA and get it inspected. It's has a kind of 30 day plate and we are running out of time on that. But to have my garage buddy back and turing wrenches is just the best.....EVER!! We are just painting parts for the car right now. The goal is to get to the 5 foot, good look condition!! The major change will be the nose. The current nose is broken with a big piece knocked out around the lower right vent opening to the rad. I started to make a repair on it until Allie had the budget to buy a used one or find an aftermarket one she would like. Well, being a cheep Yankee, I troll Craigslist once a week or so for cars and parts. Low and behold, a GT2-ish nose is listed for sale local-ish and she likes it. The price is out of the budget but I take a shot at it an see where it can go. It's a full polyurethane nose of unknown maker as it has no marks on it. The plastic is very thick and strong. A few more pics and some emails back and forth and they guy just wants to get it gone. So I make a ridiculous offer of $120 and he takes 3 minutes to come back and accept!! My buddy who lives in Jersey, goes to make pic up, I send funds via PayPal (who I hate by the way) and it's ours and headed towards home here in NY. Paint match?? we shall see. I have the light grey primer on there but most of the dings I have filled seem to be over dark grey primer so I may shoot some dark grey on it before color. I'm a real amateur but have done some painting. I did spend a week at McPherson College taking a paint class and Allie spent the same week taking welding and metal working classes. This is an excellent school that has these 1 week courses for 2 weeks at the end of the semester in June for the home hobbyist. Wonderful learning place and we really got a LOT out of it. I have very low expectations and with our 5 foot goal in mind, I just do the best I possibly can. We have just primed it but it hasn't been quite warm enough in the garage to shoot paint yet so It will probably not get on this weekend. That was part of the plan but a low level parts as Allie needs to get the car down to VA for inspection as she only has a 30 day plate. http://i70.photobucket.com/albums/i1...psz1wwrose.jpg http://i70.photobucket.com/albums/i1...ps5ai8rtbf.jpg So we left off with the coolant tank replacement. What a bull$hit design to put the one hose inside the engine bay and all others on the manifold. What evil genius figured that one out?? Well, I got pissed off when I could not pull the tank back far enough to get that clamp loose because it was a screw type and NOT a spring type. It's bad enough that the bugger leaks after to PO told me they just put a good used one in but now while working to get the clamp off, I pinch my thumb and give myself a nice deep cut that bleeds really fast. So over to the swear jar and fill-er-up to pay for my lack of control and small vocabulary and get black electric tape to stem the flow. I have a moment of inspiration and grab my small air powered sawzall and give that sucker a go a cutting the stupid thing put so I can get to the clamp more easily. Buzz, Buzz, Buzz and 45 seconds later we have the tank in 2 pieces and the clamp loose and off. http://i70.photobucket.com/albums/i1...psznw4rdeh.jpg http://i70.photobucket.com/albums/i1...psgkxbbjjn.jpg And we can now see the location of the EPOXY repair that was made and is now leaking. More trips to the swear jar after make comments about the PO, his family and all of his lineage including the origin of his ancestors and this whole event. This cooling system have been a nightmare!. http://i70.photobucket.com/albums/i1...psvffsa0im.jpg The design is crap as anyone who has done this R&R knows. The manifold fits over 2 studs that are 5 times longer than they need to be, the hoses only reach to the 4x length of the stud so that makes the pulling of the manifold further particularly scary as the fear of breaking something unseen is high, at least in my tiny little swear-jar filling mind. But I have an idea that pays off, and slot that tab on the new tank so I can get it onto the bottom stud and leave the excess manifold pulling to later on. http://i70.photobucket.com/albums/i1...ps5tddvguy.jpg This trick allows a bit more maneuverability of the tank while getting that clamp on the hose tightened up. http://i70.photobucket.com/albums/i1...pseyna5n1p.jpg OK, cooling system now secure and we are ready for fill up with special german coolant and distilled water. I had drained and used compressed air to blow out all remaining water in the system, checked it all for tight and started pouring the stuff in. Got it hot, burped a lot of air out and took it for a ride. Looking good, very happy, grab overfilled swear jar and head to beer store :-) http://i70.photobucket.com/albums/i1...ps4bsp1f3t.jpg Allie comes home and wants to go for a ride in her "new car". She heads out onto our country roads and come back with a HUGE smile on her face. This is a great car and runs nice as well as sounds killer with the Top Speed full exhaust. BUT as we stand there catching up and talking cars, we see a small trickle of pink fluid run out from under the back end. Ugh, I drop into swear jar filling mode and she drops down to see what's leaking. I'm hoping hose, but she says no, front of engine, looks like water pump .... What the $&CK!!! I have been under and around the bottom of the wreck for weeks and there has never been a drop of moisture around the damn pump. This is what you get when you really can't fully test drive a new and very cheep car completely. Every step along the way to full test drive has lead to another thing needing attention. So I get online and order a new pump to be delivered overnight so we can get this in and fixed for the trip back to VA. I can't get what is considered a good one overnight, so we order a Gates that might have the plastic impeller. Well, it doesn't. We install it anyway as we are short of time. She KNOWS it will have to be changed again in a year or so and monitored in-between at oil changes to watch the bearing for looseness. It was only $76 too, but it's brandy new and not a rebuilt, from a real company, with a warranty, so maybe it will go the year. Fingers crossed. Allie digs into the Box for her first time to change the pump. Seats fully forward, engine covers off, back carpets out and the the good stuff starts. http://i70.photobucket.com/albums/i1...pszlpyw5k3.jpg Next post. ONly 10 images allowed :-( |
Fire up the ratchet and 10mm to pull the back cover, pop the belt off, and begin getting the water pump bolts out. Yes, she has pink, steel tipped, work boots!!
http://i70.photobucket.com/albums/i1...psscanp3tn.jpg http://i70.photobucket.com/albums/i1...psrl5znfxi.jpg http://i70.photobucket.com/albums/i1...pswxlejpyj.jpg Small hands are a very big part of the ease of doing some jobs. This goes very quickly with her doing the work. My big keilbasa fingers struggle in these tight places :-( I sit back and pass her tools and offer whatever info she needs (very little) and in 10 minutes she's done up top so we move to the bottom of the car to drain the coolant and get the last 3 bolts out. http://i70.photobucket.com/albums/i1...pslxgykbbd.jpg http://i70.photobucket.com/albums/i1...psruegaxm6.jpg http://i70.photobucket.com/albums/i1...psakkxso3i.jpg While the coolant drains, she replaces one of the 02 sensors, in front of the pass side cat, that has just thrown a code. These are so easy to replace.... The cheep Chinese cable and software work perfectly in reading these codes for us as well as letting us see the actual reading in real time. Such a good tool for $21, shipped for free!!!!! http://i70.photobucket.com/albums/i1...pshrrtjcpu.jpg Checking the connection on the rear 02 just to make sure all is well. Small hansd pay off on this one!. http://i70.photobucket.com/albums/i1...psddoahihk.jpg |
OK, the 10 pic limit sucks!!!!
Coolant drained, last 3 bolts out and then it water pump removal time. The offending article. http://i70.photobucket.com/albums/i1...ps5ubar12w.jpg http://i70.photobucket.com/albums/i1...ps0dyeynhs.jpg Gasket scraping ensues to get a surgical clean mounting surface and new pump slides right in. Refill with coolant that was drained (thru a paint filter) until it needs topping off. Overall about a 1-1/2 hour job with the coolant drain and 02 sensor replacement. http://i70.photobucket.com/albums/i1...psjwgkbirc.jpg http://i70.photobucket.com/albums/i1...psv6dyda4r.jpg http://i70.photobucket.com/albums/i1...ps4h9hzphg.jpg http://i70.photobucket.com/albums/i1...psok2f3x2e.jpg She gets in with one of here sisters and takes it for a ride and comes back with the BIG (pretty) smile once again, but this time there is no leaking and no filling of the swear jar!!! More to do this weekend but these are the biggies. New windshield on Monday and off to VA she will go. |
Once again, a great write up
One thing, the factory WP gasket is metal and uses no sealant. The one you took off does not look right When you get around to re-replacing the WP, check out warehouse33auto.com If you put RENNLIST in the discount code place when checking out, you get a 10% discount. With the discount a Pierburg WP is under $200. Pierburg make the WPs for Porsche and the one I bought had the Porsche number on it |
Finnegan, you are very easily Awed!!!!
Jay, I didn't know about the metal gasket and the one we took off was paper and the new one was also paper. Today was very frustrating with this stupid cooling system. But let me start with the good project of the day. The appearance of the Box is a little weak and I wanted to improve this, so I bought a small wing for the back end to ultimately go with the new nose. I know there are some that will LOSE their minds over this modification. I did read thru those old posts and somewhat agree with them. So, the mind got working and the clever parts cam e out. I put the carbide blade on the table saw and marked the shape of the bottom of the wing and began cutting away the excess part of the dam, looking to make the fit and function work like the original air dam. The fit needed some trimming and tweaking but it finally made a nice fit and it was off the the garage to throw a coat of semi gloss black on it. Then to the install of the wing. The hole that they give you to work thru is quite small and I used allen screws which limits the throw of the wrench and makes for a slow install. I think it came out quite nice except for the paint match. http://i70.photobucket.com/albums/i1...psio9ennki.jpg http://i70.photobucket.com/albums/i1...pspmnvrlyk.jpg http://i70.photobucket.com/albums/i1...pst2izrujw.jpg http://i70.photobucket.com/albums/i1...psuefqgwxi.jpg http://i70.photobucket.com/albums/i1...pstgr12nex.jpg http://i70.photobucket.com/albums/i1...psb5c6jict.jpg http://i70.photobucket.com/albums/i1...psiujf34ko.jpg Now on to the cooling system :-( Grrrrrrr. We topped it off and took the car out for a long shake down ride. 25 milers in we stop for gas and fill up. Start up and continue on. Cooling system is acting normal and going up and then back down. Allie has some speed on going up a long curvy hill and all of a sudden she looks down and the temp gauge is almost to the 250 mark and the red light is flashing. We pull over and sit for a while to cool down and then open the coolant cpa to see how much coolant is present. Well, after some steam and some liquid release, we refill with water but since it's hot, needle at the 0 in the 180, she won't restart. She cranks over plenty fast and we hear it trying to fire but no joy. We wait ands try again, same thing, plenty of crank no fire. Wait and try but now battery is beginning to show signs of weakening. We have to call Missus better 7/8ths to comes rescue us as we need a jump and I'm fearful of a full on overheat and seizure. My better 7/8ths arrives on the scene and with cables it jump started and the temp is 180. Once underway we see the temp rising so we pull over and get the tow strap out. Tow home and add some money to the swear jar. Looks like we have 2 separate issues: Overheating with no heat. I have ordered a new thermostat and hope this is the issue. I don't know and I'm beginning to throw parts at it. Not a good strategy.... Hard to NO start when HOT. I did some research and there seem to be 2-3 issues that might be involved here. The crank position sensor failing, a vacuum vent thing on the intake manifold leaking and maybe something else I can't recall at the moment. I have a CPS in the garage and Allie will change that tomorrow. But what else could it be?? I need help with this one....... |
Very interested in how you managed to modify the aftermarket spoiler to maintain the air dam characteristics. Can you post a how to when you get a chance please.
Did you think to feel the radiators while you were stuck on the side of the road waiting for it to cool down? If they were cool then that's a good sign as you want to find the system isn't cooling - rather than the engine is making more heat that the system can handle.
I like your plan to replace the thermostat and CPS. It will be interesting to see if you find anything jammed in the thermostat. Were all pieces of the gasket accounted for? It's tight in there and easy to do... p.s. my daughter (Tilly) is 10 months old, I can't imagine how proud you must be to have your girl spending time at home with you in the garage. Whatever else you have or haven't done with your life, at least you know for sure that you got that fatherhood thing RIGHT!!! Good job. |
Aluminum is soft like wood and the alum is quite thin, so it doesn't even slow the saw down. It takes a few trims to the the fit I want and I got out for a test fit after dulling the razor like edges. The fit is off slightly so back to the saw trim a wee bit here and a wee bit there and we have a very good fit! Paint it black and install. The areo guys won't have a stroke and an air dam vs. wing jihad. I can go back to my project knowing the is have the best of both worlds!! Better looks and proper air damming going on. I should run the UN. Red Neck, Yankee engineering wins again. |
jc - when you ran the car with the new coolant and pump, did you have the chrome D shaped ring (expansion valve mounted on top of the plastic coolant tank) lifted in the up position?? You mention Allie saw the temp gauge going up and down before it pegged - to me that indicates air in the system. Every time I have replaced my coolant or pump, I leave the valve open for a few days (or several complete heat cycles) just to rid the system of air. And every time it cooled (overnight) sure enough I had to add coolant to bring it back up to the max mark.
Why the car failed to fire after stopping maybe another problem but I'll bet its got something to do with the excess heat.... |
I did have the vent or bleeder open and i noticed that is opens when the cooling system is under pressure. This figures as it's working against a spring....
New thermostat arrive late yesterday and Allie had to take the Mini Cooper home as the Box just wasn't ready. No breakdowns on the Jersey Turnpike allowed. Will put the new thermostat in today and begin the process again. Also CPS will go in too. Time to resolve the hard start when HOT issue as well. I will update when I have some new pics and info. Thanks for the input. |
The cooling system saga continues. I guess y'all are tired of this already but I think I have gotten to the bottom of my issues with the cooling and may have gotten the hard start issue resolved...
Initially, it was a leaking oil cooler that was allowing oil into the coolant. Then Once that was fixed, I was finally able to drive the car, it got hot and overheated. This I thought was the coolant tank leaking but it was a hose that blew off that BACK side of the manifold that went from the cooler to the tank. This was a PIA to fix because the back side of the manifold is deep in the dark corner of the engine bay. Long arms and no way to see what I was doing, made this quite difficult. Stubbornness can be an asset with these kinds of mechanical issues tho. Once that was on and not leaking, the car again overheated and so did my language... I did have the new coolant tank on hand because I ordered it when I thought is was bad but the hose had blown off. The old tank had a crack in it that was not visible but allowed water to leak out..another overheat and another FULL swear jar. So, installing the thermostat is a pretty easy task. Lift the car, drain the coolant and unbolt the housing. First of all, it's not easy to figure out what you get when you're buying this online. Some show the thermostat, some the housing and some both. Well, I took a shot at one that had the picture of the actual thermostat as that is what I really needed and imagine my surprise when I opened the box and the full set was in there; Thermostat, housing and gasket!! Break out the wrenches and get that bad boy off the side of the engine. http://i70.photobucket.com/albums/i1...psqoqvgtly.jpg 4- 10mm bolts and off it pops and some coolant rushes out. I had my bucket at the ready and caught 95% of what can raining down. Well, this is what I expected to see as the thermostat is held into the housing and not onto the engine. Nice and clean in there and no debris. http://i70.photobucket.com/albums/i1...pshnxx5wuf.jpg So now to inspect the housing and the old thermostat. I intended to take it out and boil it on the stove just to see what was going on. Well that isn't an option with this setup: http://i70.photobucket.com/albums/i1...psp7l9ixfj.jpg Hmmm, the old thermostat seems to have melted away or something!! Maybe they should have use those idiotic Torx security bolts on the thermostats!! Looks like this is what kids really want to steal... Well, this could be part of the problem. No thermostat allows the coolant to move to fast thru the radiators to cool down and shed the heat. This over time will let the engine overheat. It was a common thing to do when I was a kid and we were running race cars at the local dirt track. We didn't want a thermostat failure so we popped the center out to provide the needed restriction in coolant flow but not have a mechanical part that can fail mid race. We had lots of other failure, but I digress to far.... The new one looks good and will replace the missing part. http://i70.photobucket.com/albums/i1...ps2ppqt5to.jpg It has the proper gasket, but being old school, I still use a really small bit of sealant on gaskets like this. I got to love 3-Bond, while working on my motorcycles. So I continue to use a small thin coating (not slobbering) on these surfaces. A very small amount goes a long way, so use sealants in moderation! Sort of a belt AND suspenders approach to leaks. Now, on to the Crank Position Sensor (CPS), to try and get in front of the HOT hard starting issue. The CPS lives in a dark place like the back of the coolant manifold. The red arrow is the actual location of the CPS and the blue arrow is the wire that goes to it. It's tucked away on there. It's not tight, but there are lots of things in the way. http://i70.photobucket.com/albums/i1...psmcydzrdj.jpg It's in there, held in with 1 allen screw. Look deeply into the cavern and there she is. http://i70.photobucket.com/albums/i1...psvjabffsh.jpg CPS plug, is the gray one and the Back 02 sensor plug is the black one in the way and needs to be unbolted from the engine. No need to unplug it.. These are up behind the exhaust, axles and frame pieces. They are both hard to unplug. To remove the CPS I had to remove the right rear wheel and use an 18" extension on my ratchet to get in there and turn out the 5mm Allen bolt. Once the wheel was off and the long extension it was a minute to get it out and the new one in. OK, so we pour the coolant back in, add some new, break out a new gallon of demineralized water and top off the system. Fire up the engine, let it war and burp what air comes out. Feeling good about having a thermostat in the engine now and hoping this is the END of the overheating. Top it off and go for a quick spin. Well, this did not end like I wanted. The temps climbed after a short while and when the needle got to the middle hash mark, I headed back to home. http://i70.photobucket.com/albums/i1...psplcacgx4.jpg I open the trunk and see steam. I have seen this each time I came back and i was thinking that this is just water steaming off that was splashed around during the refill. Since it's gotten hot than I'm comfortable with AGAIN, I head to the swear jar in advance and empty my pockets. Missus better 7/8ths hears the shouting outside and comes to take a look at what the commotion is all about. She's used to the garage sounding like a Tourette's convention when things don't go right but this was alarming in her opinion. Steam from the coolant tank and a high temp is bad, bad, bad. Why does steam come from here??? http://i70.photobucket.com/albums/i1...psrzug7ghz.jpg Well, I can tell you why... Missus better 7/8ths comes out and looks in the trunk and says; there is steam coming out of that little box thing back there! That can't be good. Well, I bite my tongue and don't make the "captain obvious" comment and go over to stare holes in the coolant tank and begin to think about cracked heads. That is a dark place! Well, the Missus looks closely and turn to me to ask why is water squirting out of that black thingy with the shiny screws all around it. Even a guy having a Tourette's attack knows that coolant should not be coming out from back here. So we look closely and see a stream of water from the bleeder valve that shouldn't be there. Brand new OEM tank and it's defective. Back to the swear jar and it's full so I begin to fill a box. http://i70.photobucket.com/albums/i1...pshme58sbt.jpg Why does that have to be leaking?? Well at least it is replaceable. I have the old tank still so I remove the valve from that tank and mount it to the new tank. This worked and made a good seal, so I went out for another spin and this time the cooling system worked like it should. The needle of the gauge stayed very steady in the middle of the 0 the whole time. After about 10 minutes the little red light began to flash for the coolant tank being low and that is to be expected as air makes it's way out of the system. I headed for the garage and there was no steaming, no overheating, and no swearing. http://i70.photobucket.com/albums/i1...psy8nghkqf.jpg The car also started when hot, not easily but it did start. I have to work on this a bit more I guess. |
Stay with it - compulsive reading for an old swear jar owner like me....
Every time I have bled the cooling system (1 x water pump & T'stat, 1 x coolant tank 1 x coolant change) the temp gauge has also gone higher than normal on the initial drive, only to settle back after cooling overnight and refilling. The M96 engine seems to be very susceptible to air locks, broken pump impeller blades and missing thermostats (?). Looking forward to episode 64 where the mechanical hero finally drives the car more than 25 miles, quits swearing and drinking beer and gives the procedes to the local Porsche dealership.... |
There are some pics in the thread. What would you like to see?
I'm retarded. I saw the pictures. I think will do the same. Love this post and have turned the shop that's doing the 3.6 swap onto your post.
Just a quick update:
That Box has earned the name Stella. Nice name for a car but I'm making reference to Brando and screaming Stella.Every time I find another issue, I get to do my impression.... https://www.youtube.com/watch?v=G7a1TxVV4Bg And then head to the swear jar :-) I'm still chasing the overheat issue. New cap, new bleeder diaphragm, $100 in antifreeze spread around on the local roads, a few trips to the swear jar and after 2 weeks of travel and no time for working on the car, it looks like we might have a leaking radiator up front on the drivers side. While I was away, I parked the car nose down in the drive, we have a slight slope and this would allow the tank to be high and help get the air out. I left the cap off the tank and while away, and while speaking to Missus Better 7/8ths, she mentions that there is water running from the car down the drive. Well, lo and behold we have a drip when the cap is off (no vacuum) when it filled up and not sealed. So the rad has a hole in it and will need replacing. THEN maybe I can move on...... |
maybe you should just fill the cooling system with water until you figure out the problem. Once it's good, flush and fill with the virgin unicorn semen Porsche calls coolant
That is the plan. I thought is had it wrapped up when I put the expensium coolant in there. I won't make that mistake again!
Working to replace the drivers side radiator. New one arrives tomorrow and should be ready to go right in.
Removing the front bumper cover is quite easy and reveals the plastic scoop things. Then when you pull them off, out falls a pile of leaves. http://i70.photobucket.com/albums/i1...psn3prq944.jpg Not the dog, just the leaves. http://i70.photobucket.com/albums/i1...psysfdrxge.jpg Next is to loosen the AC condenser to see what's back there. http://i70.photobucket.com/albums/i1...psl5sfcfkx.jpg You have all heard it before, but CLEAN those radiators!!!! You can see the leaking along the bottom of the rad. It's corroded/rotten like. http://i70.photobucket.com/albums/i1...pssezc8o3h.jpg http://i70.photobucket.com/albums/i1...ps6y3l1id4.jpg I'd like to meet the guy who installed this clamp. Top hose, against the frame rail. Luckily, it has a 7mm hex on the clamp and a 1/4" drive ratchet fits in there and can swing a bit to loosen it. http://i70.photobucket.com/albums/i1...pseujlswo2.jpg New rad tomorrow and we may be non-overheating..... |
never a dull moment
What's the rad on the other side like? If one has corroded out, the other won't be far behind....
You can grow spuds in the compost between the rad and condenser - ask me how I know. |
The other side looks good and was very clean. The bumper cover on the right side has a big crack in it so I think it was replaced once upon a time.
Nice job with all of this. Just as a reference, when I run my car, the temp needle never gets past the 8...
http://i869.photobucket.com/albums/a...ps1fvqqkb2.jpg |
This is one of the best threads EVER!!
And I mean this in the most respectful way possible - but I am glad to read that I am not the only person on the planet who ends up doing a job three times to get it right! I feel your pain in every post! I also do a lot of work with my son's and its great to see another Father working with their son/daughter. Kudos! Keep up the good work! :cheers: |
I just finished reading all four pages of the thread. It was like a good book I couldn't put down. There were so many great story lines. I have to agree with Tom. Anytime you can do a project with one of your kids it's a good day. Nice job, great write-up. Thanks for sharing!
So. ...what is the latest?
Well, an update won't hurt I guess.....
We spent the MONTH of December ( I kid you not) moving from our home for the past 15 years in NY to our new smaller (1/3 the size) early retirement home in MD. This was an epic and painful process. I will get my advice out there right away. NEVER move!!!! If that isn't possible, take all things you truly MUST have and place them in an anonymous storage unit, find your deed and homeowners insurance, go over to the furnace/boiler and begin rubbing them together. You get the idea..... The Box was put on the back burner on about the 4th load of stuff here. It was running good but without time to fully run and drive to make 100% certain our cooling issues were behind us. We put it in the trailer and moved it to our newly rented shop in MD. We found a place right up the street that is 1500 Sq. Ft for all of the projects and to store some household items. This pic shows about 2/3 of the shop size. So, Stella (the Box name) sits there until I return from a cross country business trip. Once home, Allie and I will be actively working to finish her up and get her on the road. We are 3 hours closer to Allie's home in VA so she can just pop over on weekends to work on our other projects. |
And that looks like a Mini Countryman with a 1967/8 UK registration, No?
Brings back happy memories.... |
