Old 08-29-2015, 05:49 PM   #1
starter replacement
my starter bendix has been squacking more lately so I spent two hours replacing it with a new one this morning. Not too bad of a job. More work than most cars. I had to disconnect the inlet air, the AOS hose, a stand up bracket for the air inlet hose, loosened the clamps on the inlet manifold and the electrical connector and rotated the inlet manifold upwards. Removed the two electrical connectors from the starter after disconnecting the battery positive terminal wire. Then the first bolt on the starter came off pretty easy, the lower one was less accessible but after I removed the AOS hose, I had enough access to get to that pesky lower bolt. Reverse order was much easier after lessons learned. New starter, works great.
Then I went to install some LED tail lights I got in the mail today and they only work on the marker lights, the signal lights and the brake lights do NOT like LED's. So, I put all the original incandecent bulbs back in.
My son and I also put up 12 truck loads of Silage this afternoon. We live on a cattle ranch, My Dad and I run about 170 head of Black Angus cattle.
Old 08-29-2015, 08:48 PM   #2
Pdwight's Avatar
You are a hard working man....not because of the starter.....the Cows....my father in law raises Beefmasters
Old 08-29-2015, 09:08 PM   #3
Motorist & Coffee Drinker
78F350's Avatar
I read your post and remembered this picture from the Pelican Article when I did mine. That lower bolt can be accessed from the front with a long extension. It was almost easy (keep a telescoping magnet on hand).
Old 08-30-2015, 07:01 PM   #4
I suspected there was a way to access it from the front. Once I removed the AOS hose I was able to get a small wrench on it and get enough motion to break the bolt free and then work it out with my finger tips that could just barely reach it.
