Old 01-05-2018, 10:01 AM   #41
I would like to do this upgrade in my '98 and picked up a used dome light off an '08...... What is the best way to mount the electrics.... I understand the connector is different.... So I guess I'm asking where can I locate the correct connector to make The '08 light work in my '98.
Thanks!
Fred
1096369fred is offline   Reply With Quote
Old 01-05-2018, 02:34 PM   #42
I JUST Put an LED light in there.
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
Old 01-06-2018, 05:24 AM   #43
oldskool73's Avatar
@1096369fred : it's a pretty simple 3 pin connector, I used one from a motor that came with an Arduino kit I had lying around, you could try taking it to local hobby/rc/parts stores and see what they have that would fit.
oldskool73 is offline   Reply With Quote
Old 01-09-2018, 06:50 AM   #44
mikesz's Avatar
Not trying to be a ahole but why do you want to do this? What is the difference in lights? Just asking because I am a diy'er so always interested in what others are doing to upgrade their cars. I have a 99.
99 Porsche Boxster
Old 01-09-2018, 03:35 PM   #45
oldskool73's Avatar
@mikesz - if you look at the pics in the first post I made, the original ones are held in with little plastic tabs that break easily when you try to pop them out to change the bulbs (or just over time). The new ones have metal tabs. That's the main improvement.
Old 03-02-2019, 05:49 PM   #46
Just got an 01 Dome for my 97 and I’m in need of the 01 connector. Can anyone point me in the right direction?
CigarGabe is offline   Reply With Quote
Old 03-03-2019, 05:22 AM   #47
KevinH1990's Avatar
You may need to check several sources:
1. Check the parts for sale section on this forum and other Porsche forums such as Renntech and Rennliist. Woody (member name Itsnotanova) has helped me in the past. Send him a text and he will respond quickly.
2. Wrecking yards - I purchased my light and connector from Specialized German.
Before you buy the connector, I recommend that you check the wiring in your car. I don’t know which year Porsche changed the design, and your 01 light may be the same design as the one already in your car.
Old 09-01-2019, 10:12 AM   #48
mrw
Swapping dome lights from rocker to switch
You can reuse the connector pins from the rocker light and connect them to the newer dome light as shown in photo. Easy solder job
mrw is offline   Reply With Quote
