08-16-2015, 07:10 PM
Smoke coming out of the intakes.
Im waiting for a flat bed luckily.. not far from home. Smoke is pouring from the intakes and wheel wells. Smells toxic like cooked rubber. Coolant tank is fine, nothing unusual on the gauges. This was the first long drive since recently cleaning the MAF after getting P0153 and bouncy idle which helped some what. Doesn't seem related though.
08-16-2015, 07:17 PM
I am my own mechanic....
AOS dripping oil on exhaust. Or some rubber tubing on exhaust. If temp needle didn't rise, some external failure is my hope for you, bud. Good lucks!
'08 VW Touareg T-3 wife's car
08-16-2015, 07:30 PM
Man that really sucks! Could it have been a power steering hose leak? Hopefully something simple. Good Luck
08-16-2015, 07:47 PM
Sorry for the breakdown. When did you notice the smoke?
Let us know what you find...
08-16-2015, 09:27 PM
I noticed the smoke while driving home. I thought it was a jalopy in front of me. Nope its me... that smell of burnt rubber (belt?) was intense and lingered for a long while. The smoke started up pretty suddenly. I didnt get two blocks up the street before I pulled over and shut it down. Steering seemed fine. I did notice some condensation on the exhaust pipe when I first fired it up. which seemed odd being that it was parked in a pretty hot garage.
Actually I dodged a bullet as I nearly took the car for a very long drive to a remote part of New York (Port Jervis area) where there is zero cell phone coverage, barely any street lighting and very little mass transit. And forget about Uber. The MAF issue was enough to convince me to leave it at home. That would have been a disaster.
P.S.
I tipped the tow truck guy 25%...the GT3 bumper just barely clears the flatbed with the wooden ramps...barely.
08-16-2015, 11:13 PM
When I had those symptoms it was the clutch unit on
Air con pump,
08-17-2015, 06:50 AM
Sorry to hear about your issue. Hope its nothing serious, please keep us updated if we can help in any way. Good luck.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
08-17-2015, 08:46 AM
Since it's a burnt rubber smell - possibly any one of the Belt drive pulleys began seizing up causing the serpentine belt to burn?
Good luck from a fellow NJer
Probably going to be another preventive maintenance item to add to the list
Seal Grey
08-17-2015, 08:56 AM
I hope it is nothing major
08-17-2015, 09:09 AM
Air con pump,
Me too on my Tacoma. The compressor seized up and smoked the belt and melted some stuff inside the compressor which oozed out and solidified into a plastic lump. Luckily? The compressor ran on a dedicated belt so I was able to cut that belt and keep going.
08-17-2015, 09:16 AM
I should have taken a look in there. But man was that smell overwhelming.
I think I put S-belt #2 in there about 30k miles ago. Seems like a big hunk of tough rubber to cause that amount of smoke. I had the AC blasting full throttle to get the fans on after getting caught in traffic with high ambient temp. The coolant temp was inching closer to the 1 o'clock. About 10 minutes after breaking clear of traffic and pulling off the highway the fireworks show began. I guess as k9dbm mentions it might be the AC pump (so that's another device that has a clutch I didn't know about).
p.s.
Can you rig the fans to turn on without turning on the AC?
08-17-2015, 09:26 AM
p.s.
If you have a durametric connected, you can manually turn the fans on
08-17-2015, 09:41 AM
Clutch on drive pulley for the AC compressor is pretty standard for most cars. I had one go bad on my 2003 jeep liberty. Fortunately, for that car, there is a clutch kit for $80 you can buy and with a loner pulley puller and an hours + time, got-er done
I have to search to see if there is a similar kit available for the 986
I finally used my AC yesterday and was glad 1st it still blows cold air and 2nd the pulley clutch didn't freeze up
Seal Grey
08-17-2015, 10:16 AM
Good luck with this. I'm interested to find out what caused this. Maybe check the air filter for anything odd caught in there?
08-17-2015, 11:22 AM
Master Brewer
Did you suck something up into the motor. I've read posts where folks have sucked plastic grocery bags up into the engine and holys#@^. Realize this sounds too easy but thought I would add it. Good luck, hopefully it's simple.....
____________________________________
2004 Boxster S Anniversary 550 Spyder
2018 Porsche Macan (wife's ride)
2004 Ford F-150 4X4 Crew
6 Fast Bicycles
08-17-2015, 02:18 PM
My bet is on the belt. With the AC on, it puts more load on the idler pulleys and if you have a bad pulley (or an about-to-go-bad pulley), driving with AC on can really push the bad bearing over the edge. Happened to me recently, though luckily the bearing in the pulley was so shi**y that the balls just self destructed instead of swelling and seizing the bearing.
08-19-2015, 02:46 PM
AC compressor indeed....
New unit along with belt tensioner and rollers (preventative) parts are $900 and labor is about 9 hours.
:ah:
08-19-2015, 05:32 PM
You turned the A/C on to get the coolant temp down? Wouldn't that have the reverse effect? When you say 1 o'clock you mean inching towards 250? I've never had mine go much past the '8' (just left of noon on the clock dial) even while sitting on a hot/humid day in traffic for an hour with the A/C going. The secondary(?) fans turn on by themselves regardless if my A/C is on.
08-19-2015, 05:49 PM
Wow. Seriously? Mine always danced around the 0. Even with three big ass radiators now, I still dance around 0 (but I also have a bigger engine now).
I also live in Arizona where temperatures are excess of 110, but yea.
I think he turned his AC on to get his fans running, but if the ECU worked, the fans should turn on automatically.
99 Porsche Boxster 986 3.8
85 Toyota Corolla AE86 F20C
12 Honda Accord
16 Mercedes C450 AMG
22 Tesla Model X Plaid
08-20-2015, 07:20 AM
when I'm in stop in go traffic, a lot of that idling in neutral, which is terrible for the engine, I rarely hear those fans go on by themselves right away. My thinking was that the AC speeds it up.
