Old 08-11-2015, 04:39 PM   #21
Beginner
Jamesp's Avatar
On mine there were two hot lines into the unit. One of them (the thick red line in a 2003 harness) is always on, that goes to the line marked B+ (or +12). The other line is the ACC line, this one goes on and off with the key. I had to run a separate line for ACC. If the unit loses 12V in it will lose its memory.
2003 S manual
Old 08-12-2015, 06:40 AM   #22
DrCactus's Avatar
Guys - is it possible there is some sort of DEMO or seller's store function on the stereo that would cause it to reset each time I turn the car on... as I noticed my Bluetooth setup is saved but none of the visual settings on the stereo ...
DrCactus
Old 08-12-2015, 08:05 AM   #23
EJ-Fresno's Avatar
Try to make a factory reset once and see if it saves your settings afterwards?
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 08-12-2015, 08:40 AM   #24
Check the manual?
Old 08-12-2015, 11:45 AM   #25
epapp's Avatar
There is a CMOS battery in most double din units that allow the persistent settings. Most China head units will sit in stock/use cheap batteries and by the time the consumer gets the part, the battery is dead. The battery is easily replaceable and normally lasts many years (if you get a name brand). I suggest taking the unit out and replacing the battery (it's normally a coin style battery, one of those CD2032)
epapp is offline   Reply With Quote
Old 08-12-2015, 04:24 PM   #26
Beginner
Jamesp's Avatar
Check the manual?
Cheap Chinese unit = no real manual. I have data.
2003 S manual
