Old 04-25-2006, 03:04 PM   #21
Originally Posted by bmussatti
What about the vibration issue with the faulty oil relief valve? There is a TSB out on this. Looks like an easy fix too. Go look over on the RennTech site for more details. Loren there had a good post with the engine numbers involved on some specific 2005's.
thanx - will check it out
Mach Schnell
05 Mini Cooper S
CR/W - AC Schnitzerz'd, Alta CAI, Cravenspeed SSK
Japanese Rising Sun roof graphic
De-ambered and nearly de-chromed!
Sold - 05 BMW 330CI ZHP M-tuned
Imola Red, 6spd, Alcantra & Carbon Fiber Interior
Sold - 05 Boxster Black/Black 5spd
19" Carrera S Wheels
Bose Audio System/Sport Chrono Pkg
Schnell Short Shifter
Yellow Calipers c/ carbon fiber Porsche lettering
De-Ambered
Sold - 03 VW Beetle Silver - way too modified!
mach schnell is offline   Reply With Quote
Old 04-25-2006, 03:57 PM   #22
bmussatti
Guest
Posts: n/a
mach schnell, the TSB# is ENU1726 for the following engines:
The TSB says the new control spring is "as of":
Engines manufactured since December 5, 2005 as of engine numbers:
M96.25 61 6 04763
M96.26 62 6 03668
The date is not that important (except that if your car was built before that date it couldn't have the new control spring). If your engine number is below the engine numbers above (depending on model) -- then you need the new control spring.
You can find your engine number in either your warrenty book or owners manual. I don't remember which. It is in the first few pages.
I hope this is helpful, but your vibration sounds like it is much worse than the issue covered by this TSB.
Good luck and let us know how it works out with the dealer.
Old 04-25-2006, 04:51 PM   #23
bmussati - so are you saying that if I have an engine number DIFFERENT than either the two you listed, I potentially have the faulty oil relief valve? Or are those the engine numbers that are specific to the faulty oil relief valve?
Mach Schnell
05 Mini Cooper S
De-Ambered
Old 04-25-2006, 06:12 PM   #24
bmussatti
Guest
Posts: n/a
mach schnell, sorry. I edited the statement to include:
Old 04-25-2006, 06:29 PM   #25
Hi,
The speculation here is all over the Map. But, most vibrations are either RPM or MPH dependent. If RPM, then look to the Drivetrain, if MPH, then suspect the Tires, Suspension. I'm going for the latter based on what you've described. Good Luck!...
Happy Motoring!... Jim'99
Old 04-25-2006, 08:47 PM   #26
in leiu of the tires magically falling out of balance, what is the likelihood that the suspension is f-ed up in a new car with 4k miles (no sarcasm here - real question). i have to admit, i feel like the car is wobbly even on gentle corners (even with sport-mode engaged) - however, i may just be imagining every little thing until i get to the bottom of this vibration!
Mach Schnell
05 Mini Cooper S
De-Ambered
Old 04-25-2006, 08:56 PM   #27
Hi,
I can't imagine an issue with the Suspension on such a new car, except if something wasn't properly torqued on the Assembly Line and has now shifted. But, have you hit any pot holes, curbs, speed bumps, even a sharp driveway, or the like? You could have delaminated a Tire causing the vibration.
Your Tires and Suspension are virtually new. Well, manufactured things tend to fail at one of two stages - in their infancy or old age. The first because of poor manufacture or assembly, the latter due to old age and simply wearing out.
In either event, everything discussed here is sheer speculation and can only be confirmed by visiting the dealer, or a tire & alignment shop and getting these things properly measured to insure they're within spec. Gonna cost some time and maybe some $$, but there's no other way except to live with it, which I certainly would not. Hope this helps...
Old 04-27-2006, 04:59 PM   #28
well - 987 going into Walter's monday morning to sit while they come up with reasons why there is no vibration
incidently, i throughout the idea of the control spring for the oil relief valve as a culprit and the service rider was clueless! who knows - will provide updates next week.
by the way - re: loaner car - Angie, the service rider confirmed when I made the appt today, that I'd have a loaner car ready monday morning when I drop my car off - no charge, unless I upgrade to the MB.
Mach Schnell
05 Mini Cooper S
De-Ambered
Old 04-28-2006, 07:10 AM   #29
Mach, there's something you should know about warranty work at Porsche dealerships that I just learned from my mechanic, who is a tech at a dealership.
Rattles, squeaks, noises and vibrations (even bad ones like yours), etc. are all justified issues on new Porsches covered under warranty, no doubt.
However, Porsche does not pay the normal labor rate to techs to find these things and resolve them during the warranty period. Therefore, they are always wiggling out of working diligently to find your problem.
Moreover, if the fix for the issue does not include replacing any parts, the dealership makes no money on the service work.
On another note, Hans told me that if the book rate for a repair is 4 hours and it's warranty, Porsche will only pay 60% of book rate to him to fix it. However, if it's customer-paid work, you get charged all four hours, even if he does the job in 2.75 hours, which he typically can do because working longer doesn't pay him any more.
Imagine sitting in a waiting room for your car, working on your laptop, which I've done three times now. The service guy quotes 4 hours, the mechanic is done with it in 3 or less hours, but leaves the car on the lift, goes to lunch works on another car, cleans his tools, tells a buddy a joke, and all of this just to make you feel like you paid for 4 hours labor.
I know this is how all dealerships work, but it pisses me off. It's cheating the customer in a big way.
All this to say, mach, know you're going into warranty issues with people who don't feel they are paid enough to do the work you paid for when you bought your very expensive German car.
Old 04-28-2006, 08:46 AM   #30
Randall - I know that getting down to the bottom of this vibration problem is not going to be easy (but, who knows, maybe the big overseer of all that happens on this planet will throw another pigeon into demise - like into the mechanics head - and a mild concussion will spark the otherwise lowly motivated porsche mechanic to actually discover something...). However, this is a matter that i will pursue to great lengths. i figure, if anything, the dealer will get tired of paying for my loaner car, since they will have my car often if the vibration is not fixed, that they will begin actually searching for the culprit.
on the other hand, if i fail with them, perhaps i'll try an independent certified porsche mechanic - see what he finds - and then take that info back to porsche. - only thing is, i can't justify at all, having to pay out of my pocket for warranty issues - that's why i bought a new car and not a used one. need to find out if i the cost of seeing an independent cert mech will be reimbursed by porsche (yeah, right!)
i've had my vw beetle for over 3 years - have over $5000 in modifications to it - driven it across the country once - and have only had to take it in for a warranty issue, 1 time. it has always started and always gotten me to where i want to go. sure it has some little rattles here and there - but hell it's a less than $20k car - i'll forgive that. maybe i'm being more picky with the porsche - but i think that is justified. i really wonder now, would i have made a better choice either buying a G35 or 350Z (thereby avoiding quality/mechanical issues) or should i have opted for a used 911 or m3 (as were my original intentions - decided against, thinking that warranty and mechanical issues would be avoided with a new German car), since it looks like i'll be dealing with this problem anyway?
the final thought, as painful as it will be to follow through (ya know, like the wounded little kid who has been bragging and bragging about how good his hero is, only to have to admit that maybe his hero is not that above average...) is that i let the car go and maybe take up the porsche dream a little later in the medical career when i have more disposable income to throw to such "common" issues that are perhaps part of owning such 'fine' german metal! i hate to sound like a fair weather porsche owner, but it really is hard to have feelings of excitement (and security) in a car that you constantly doubt its integrity!
alas, i yearn for the lazy hours of the weekend, yet yearn for monday to arrive, as the future may reveal ones fate...
Mach Schnell
05 Mini Cooper S
De-Ambered
Old 04-28-2006, 08:47 AM   #31
Mach Schnell....
When I drove an '06' S last fall --a car with 10 miles on it-- it had a vibration that went the length of the car and felt like it was on the centerline of the car. At a particular rpm (2000-3000) the car really shook. I'm not sure what is was but it was startling.It was the type of vibration that I had never experienced on a Boxster before--986 or 987.
Had it happened on the car that we bought, we would not have taken delivery until it was fixed.
Keep us apprised of how Porsche deals with the problem.
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
MikenOH is offline   Reply With Quote
Old 05-01-2006, 01:29 AM   #32
You didn't say anything about whether it happens at specific speeds, but I had a similar problem in the high 60's to 80mph range and it turned out that one of the wheels was way out of balance. I have the adhesive weights and at least one had fallen off. A rebalance solved it.
CA_Boxster is offline   Reply With Quote
Old 05-01-2006, 12:18 PM   #33
box is in today - leading theory (at least when I dropped it off) was an out of balance wheel - hoping that Occam's razor applies here as i don't want it to be something major! Vibration or shaking through-out car is totally speed related - notice at about 65 - obvious above 70 and you want to pull the car over, get out and above 80!
on a side note - picked up a nice C class sport as my loaner - this could make a new car for my wife (she needs to learn how to take care of the car she has, first ). Even though there are a ton of these on the roads here in soCal, i really like it better than the 3 series bmw.
turns out, though, that although the loaner car is free the first day, I get charged starting the 2nd day - something like $37/day. i really don't think i should have to pay for a car (that's what i did when i bought the porsche!) to drive when my car is in the shop for warrantable service. i'm in the wrong business - maybe doc's should be able to just bill people for walking by the hospital
Mach Schnell
05 Mini Cooper S
De-Ambered
Old 05-01-2006, 12:36 PM   #34
I'm in the wrong business - maybe doc's should be able to just bill people for walking by the hospital
My doctor sure did just that... put me in the hospital overnight two weeks ago to rule out my heart so he could prescribe some gastric reflux medicine. It's costing me a nice set of 18's AND a replacement top for the Boxster beyond what my insurance will cover.
And I have yet to see the bill for the doctor, who will surely bill me for walking past my room when I was taking a leak in the bathroom.
BTW - no heart problems... as I suspected.
Old 05-02-2006, 12:08 PM   #35
Brad Roberts's Avatar
What I have done in the past: Take the service writer for a ride. Make a mental note of where the car had the issue last as you drive towards the dealer. Take the service writer back to that same spot and duplicate the problem for him. 99% of all the dealers have a routine "path" that they follow on all test drives. This "path" may or may not duplicate your problem.
Oh.. ask them to TAPE all the weights on. It is is the ONLY way to gurantee they wont come off. It is very easy for a "grunt/tech" to bang the inside of the wheel on the caliper as they try to mount up your 30+lb 19inch wheel/tire combo thus possibly loosening the weight they just installed (or did a brake inspection).. The possibilities are limitless on how easy it is to knock a weight off.
B
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
