			Hi,
 The speculation here is all over the Map.  But, most vibrations are either RPM or MPH dependent.  If RPM, then look to the Drivetrain, if MPH, then suspect the Tires, Suspension.  I'm going for the latter based on what you've described.  Good Luck!...
 Happy Motoring!... Jim'99
