Old 07-13-2015, 03:05 PM   #1
CEL went out
This is a first for me been driving 2000 s for about 1 week with the cel on and next thing i know its out.
I have not seen them go out on there own is that possible ?
I'm ecstatic, it can fix its self what a Car
Gary Treasure is offline   Reply With Quote
Old 07-13-2015, 03:16 PM   #2
jsceash's Avatar
I believe 3 drive cycle without a repeat of certain codes they reset. Most of the time O2 sensor. I've got one occasionally in the heavy rain.
Old 07-13-2015, 03:36 PM   #3
ppbon's Avatar
Also, check to see if the CEL comes on when the ignition is set to on.
If the CEL is out when the ignition is on then the bulb is burnt.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 07-13-2015, 03:39 PM   #4
Luv2Box's Avatar
I had a similar experience last year when my secondary air system valves took a dump. CEL was on for months then one day went out. Knowing that cars aren't self healing I figured the bulb burned out but a few days later it came back on again.:ah:
Luv2Box is offline   Reply With Quote
Old 07-13-2015, 05:29 PM   #5
Rookie
+1, same code, same exact experience. As luck would have it it went out just a few days before I was due to update my emissions and renew the registration. Hauled ass to the inspection station while it was out, passed with flying colors and am good for another two years. It then came back on a week later, stayed on for a few days and has since gone out again, been out for well over a month and counting. I think driving the crap out of it during the spring and summer months helps keep the periodic SAS codes at bay, but thats just a theory...
02 Seal Grey 5 Speed
TypeA is offline   Reply With Quote
Old 07-13-2015, 08:23 PM   #6
After the Porsche ECU self-repair function fixes the problem, you'll automatically get a bill in the mail for $350 from Porsche (half of the cost of the repair had you taken the car in).
Old 07-14-2015, 02:30 PM   #7
Now thats some funny stuff
Old 07-14-2015, 08:51 PM   #8
I've had that happen several times. Two years ago, I drove from Milwaukee, WI (an ethanol mandated area) to Seattle and back. About half a tank into non-ethanol gas, the CEL turned on and stayed on until about a tank and a half through the ethanol gas. Another trip to Northeast WI, I filled up on non-ethanol gas and the CEL came on half tank and stayed on until I drove on the ethanol crap for awhile again.
I am currently on a road trip through WV, VA, NC, TN and KY. Somewhere along the way I fueled up on non-ethanol gas, and the CEL came on at about the half tank level. Several days later, with multiple fills on the ethanol mix, it went off. It's been off for three tanks of fuel now.
I'm not sure why that happens, but it does. So I wouldn't freak out. Next service trip, have them check the OBD and make sure nothing's amiss, then fuhgettaboutit.
DBear
dbear61 is offline   Reply With Quote
