Old 06-16-2015, 10:13 AM   #22
edc
550 Anniversary
edc's Avatar
The advantage for the adjustable rear toe links is only of any use in the geo department. If you only run a standard geo then they are of no real benefit to you. If you like a more rear to neutral balance then the rear toe links allow you to maintain parallel toe without loads of negative camber. That allows you to dial in more negative camber on the front for a more pointy car.
