Originally Posted by Pdwight
This did not seem difficult at all compared to the engine mount. You did remove the inner fender cover right ?
Yes, I removed the cover for easier access. It doesn't seem that difficult indeed once you figure out where to locate the 18/21 mm wrenches.
I have just spent 1 hour trying to loosen the bolts on the chassis but there is no way they will move, even if I soak them in WD40...
The bolts on the wishbone came out easier...
I put some more WD40 and will let it rest until tomorrow evening. I'll give it a try once I come back from work.
Can you please guys let me know what is the best product to help loosening tough bolts? Thanks!
