Old 06-11-2015, 10:42 AM   #1
Hummer-addict's Avatar
Can You Install Clear Late Model headlights In A 1997 Boxster?
Title Says It All....I DO Not Like The Amber In My Headlights And Want To Buy Late model Headlights And Install Them...Are They Plug And Play Or Will I Be Opening Up Electric Nightmares...
Hummer-addict is offline   Reply With Quote
Old 06-11-2015, 10:48 AM   #2
Rennzenn
j.fro's Avatar
If by late model you mean anything up to 2004, the answer should be yes. There were two types of clear lights available, Litronics and regular halogen lights. If you go with Litronics, they should work but you won't have the self-leveling feature.
Rennzenn
Jfro@rennzenn.com
Old 06-11-2015, 10:53 AM   #3
EJ-Fresno's Avatar
What will be missing if one wants the self-leveling feature?
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 06-11-2015, 10:59 AM   #4
Need For Speed
KRAM36's Avatar
These should help you.
http://986forum.com/forums/general-discussions/55119-986-litronics-plug-play.html
http://986forum.com/forums/general-discussions/55840-can-you-endure-one-more-litronic-thread-me.html
You would want to look for someone selling all the needed parts, like this one.
http://rennlist.com/forums/parts-marketplace/845405-early-996-986-litronic-headlights-and-headlight-washer-conversion-package.html
Old 06-11-2015, 11:25 AM   #5
Errr ahhh the self levelling feature would be missing
In reality, litronics will be a fantastic upgrade and self-level feature not missed...and definitely not so in terms of "the juice ain't worth the squeeze". To get the feature you would at least need to install addl wiring, the headlight angle level sensor, sensor arm and sensor bracket (at driver side rear suspension) - plus I think in the 9x6 series this is a separate litronics controller in the frunk.
Good luck
"Cool Prius!"
- Nobody
Old 06-11-2015, 11:45 AM   #6
Need For Speed
KRAM36's Avatar
If you don't want the leveling feature, I would go with the GT Projector Headlight Retrofit Kit.
2004 Porsche Boxster S Convertible - Lights and Lenses - Page 4
Old 06-11-2015, 12:36 PM   #7
I have factory litronics in my 1997 with the wiring harness and NO SELF LEVELING.
The problem with the self-leveling according to my tech is that the sensor that is wired up to the control arm determining self leveling can break off. Not worth the effort to put it on IMO.
Retrofitting is probably a lot cheaper and the quality of light will be about the same if you don't get crappy components. Porsche's factory litronic projector lamps and housings and bulbs are top notch.
I love my no-amber litronics. They look great and I can see a country mile down the road at night. They're a zillion times brighter than stock halogens.
Old 06-11-2015, 01:17 PM   #8
Don't forget that early 996 headlights will also fit the 986. Check the 996 forums to find a set for sale.
Old 06-11-2015, 01:23 PM   #9
EJ-Fresno's Avatar
I thought about this...until I got to read the 24-page installation guide
2006 V6 Mustang
2008 ML 350
Old 06-11-2015, 02:27 PM   #10
I'll just leave this here as food for thought...
http://986forum.com/forums/general-discussions/51810-our-amber-headlights-can-de-ambered.html
Edit to add: post 104 is how my original amber halogen headlights now look with GT Projectors and de-ambered. Total cost with stuff I had to buy (which you may have, i.e. a Dremel) was well under $600 total. Probably closer to $500. Just takes a few days off and on if you move slow like me.
CraigM is offline   Reply With Quote
Old 06-11-2015, 03:36 PM   #11
KevinH1990's Avatar
I retrofitted the automatic dynamic headlight beam adjustment feature. I'm not sure it was worth the extra effort over simply installing the high beam rotation feature. I'd like to see how it works in a car that had it as a factory option to be sure it is actually working correctly.
The high-beam rotation is well worth the extra effort.
I have some left over parts if you are considering this. I attached the instructions.
Old 06-11-2015, 06:55 PM   #12
Need For Speed
KRAM36's Avatar
I looked at page 24. What is it on that page that makes you not want them?
Old 06-11-2015, 08:49 PM   #13
EJ-Fresno's Avatar
Not page 24 itself, it's the whole guide which is scary...to me at least
2006 V6 Mustang
2008 ML 350
Old 06-12-2015, 06:56 AM   #14
BruceH's Avatar
Send them to Particlewave(Charles). I did and couldn't be happier. I was able to find a set of new clear halogens, get the HID projectors, send it all to Charles for installation and then ship the final product to me all for about the price of used litronics. The trouble with used Litronics is finding a set where the lens are not yellowed or cloudy. Mine are crystal clear since they are new. Of course if you do find a cloudy set, Charles can help with that too.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 06-12-2015, 07:27 AM   #15
Thanks for the help guys... Would these work? Porsche Boxster Headlight Assembly w Clear Turn Signal Lenses L R New NS | eBay
Old 06-12-2015, 07:49 AM   #16
BruceH's Avatar
Originally Posted by Hummer-addict View Post
Yes, those will work. My understanding is that Automotive Lighting was the OEM vendor. I bought Bosch lights from here, but they were $400 per side when I bought them.
Left Porsche Boxster Headlight Assembly Bosch 0302473043 | eBay
I looked at buying used but the weathered lens that was typical of used pushed me to spend the extra for new. Still happy with that descision. You can always try to sell your current lights to lower the net cost.
DEPO Tail Lights
Old 06-12-2015, 07:53 AM   #17
Thank you! I just offered $600 for a used set here with slight damage...if he declines I'll buy these...and yes I will sell my OEM ones...they are in great shape!
Old 06-12-2015, 12:59 PM   #18
Usercpy
ilikeching's Avatar
You can try this:
http://www.flickr.com/photos/flickr_ching/
ilikeching is offline   Reply With Quote
Old 06-12-2015, 01:21 PM   #19
Need For Speed
KRAM36's Avatar
I had Charles do mine too. I visited him in person when he did mine, he didn't seem too enthused to do more, but make it worth his time and he might do it.
Old 06-12-2015, 03:31 PM   #20
I bought new ones on eBay today... With new oem corners for under $1100...hoping to get $600ish for my OEM Ones...they r in great shap... I want to thank everyone for thier advice!
