05-27-2015, 06:20 PM
#1
father in law drops it on me..
my f.i.l. gave me his 2000 boxster as payment for work. It was sitting on his driveway for several years due to a horrible crash on his Harley. it smells of mold inside and needs months of rehab….
can someone tell my the major things to do get it running good? should i pull out gas tank and clean it out? i know oil and filter must be changed… what is a good oil and filter to buy? i know genuine parts are the safest. if a long time owner can give me a heads up on what is in my future.. i would be so grateful. I'm in new Orleans and like to jazz it up
05-27-2015, 06:28 PM
#2
Beginner
Congratulations, let me be the first to say "pictures or it didn't happen". Don't take the tank out. You can drain the tank by removing a quick disconnect on the firewall behind the drivers seat. its under the car, above a plastic shelf just in front of the engine. You'll need a fresh battery and you'll have to jumper the fuel pump relay. Timco just did that. New fluids are in order, then fire it up!
2003 S manual
05-27-2015, 06:37 PM
#3
I am my own mechanic....
The first thing you need is a press. As in printing press. Then get the plates for $100 bills, usually on eBay. You'll need a lot of paper, too.
'08 VW Touareg T-3 wife's car
05-27-2015, 07:05 PM
#4
First, there are a thousand threads on here about oil and filters. Sit back, use the search, and prepare to be amused and bemused.
Second - not a bad idea to get it to a Porsche mechanic for a once over. Get it up on a lift and take a real, close look at suspension et al.
As Timco said - these cars can cost a mint, so best be prepared.
05-27-2015, 08:21 PM
#5
Now that was damn funny! True and funny.
05-27-2015, 07:16 PM
#6
How many years do you mean by several years?
it sounds like your FIL may be finally repaying you for more than just your labor.
BORN: March 2000 - FINLAND
05-27-2015, 07:24 PM
#7
2k13 Boxster Amaranth Red/Black
05-27-2015, 08:24 PM
#8
In all seriousness, I'd put in some fresh gas, oil, and a filter and see if it fires. If the engine starts, then I'd follow up quickly with an entire major service.
Then I'd drive it until I found a problem.
Then fix it.
Then fix it.
Then fix it.
You get the idea...
If you can DIY some of the work, I would recommend a stack about 20 high of those home printed $100 bills to get you through the first year. If everything has to go to a shop to be fixed, go 30 high on the stack. And that will just be to get it and keep it mostly running. Rehab will take a separate stack...
Did your F.I.L. mention that there are no cheap Porsche's?
05-27-2015, 09:15 PM
#9
also in new Orleans here. if you need some help with your new boxy feel free to private message me. I have figured out my way around the 986 and would be willing to assist you when I can.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
05-27-2015, 10:16 PM
#10
+ 1
isn't this place cool or what..?
05-28-2015, 04:34 AM
#11
Originally Posted by Gilles
+ 1
Oh, he'll ask about oil soon enough...
05-28-2015, 03:28 PM
#12
Not to mention the CATS…….
05-28-2015, 06:16 PM
#13
Don't let these guys put you off. The Boxster is probably one of the most reliable Porsches you can own. True sitting is never good for a car, but after a routine change of fluids, perhaps plugs and wires, a thorough cleaning of the interior, you should have the car back up and running presuming there were no prior major problems.
Pictures!!!
05-29-2015, 04:34 AM
#14
I'll reinforce that any vehicle that is over ten years old and/or has been sitting for a long time will require a fair bit of maintenance before hitting the road.
As a somewhat recent owner on the used Porsche scene, I'll try to summarize my experience for a little perspective. Some have had a horrible experience, most have had a good experience. I'd guess mine is average.
I have two '99 986s. 97,000 miles and 140,000 miles. One I've had for two years, the other for 6 months.
I took each to a reputable Porsche independent shop for a once-over. Very important on these cars to keep them up.
The first one (97,000) had been fairly well maintained, but required just under $2,000 in maintenance to be put in 100% good form. After that , it was my daily driver for a little over a year and needed nothing. (still needs nothing other than regular fluid and filter services).
The second one was much more neglected and higher miles. Had been sitting awhile. Bought as a daily driver-work car. It needed a bit over $3,000 in maintenance before hitting the road. Since then, it has been very reliable (like the first one). I drive it over 3,000 miles per month as my job requires lots of traveling. Original alternator went out, a couple of leaks were fixed, original rear control arm replaced. Otherwise has been a rock and has never stranded me. Has been through floods, blinding snowstorms, long stretches on dirt roads, highway, city, and a minor accident. Still chugging. Gets a clean bill of health at every service interval.
Will they remain ths way long-term? I can't answer that yet, but that has been my initial experience with Boxsters.
The point is, it's likely going to be a stiff initial investment since it has been sitting. After that, you could have a nice car that you enjoy for years. Just be prepared to shell out more than the average car when it does need something.
PS: In recent years, I have owned a Jeep, Land Rover, Nissan Pickup, and Ford Focus (all about the same age as the Boxsters) as work cars. Except for the Nissan, they were all less reliable than the Boxsters have been (the Rover, insanely less reliable) and not as much fun to own.
Sorry for long-winded post. I thought some detail was needed.
05-29-2015, 08:17 AM
#15
Deffered Boxster maintenance/repair is like owing money to the IRS... it only accrues with interest. the #1 truth of owning a Porsche: you can pay now, you can pay later but you will pay. Sure if the car only comes out for Sunday ice cream cones it will be reliable enough. But start pouring on the miles where climates vary from very cold to very hot and Porsche reliability becomes an oxymoron. Perhsps compared to a Ferrari it's an old Volvo...
By the way, someone mentioned comparing against an 11 year old car. Like many Boxster owners my previous car was a Miata. It is probably the most commonly found car at any track day or autocross from LA to South Florida to NY and everywhere in between. On the street you can drive the wheels off the car year round and not face 1/10th the repair costs of any Porsche and any mechanic will jump right in without saying "I don't touch those cars".
if you like to modify your cars youcan do as much as you like without spending enough to buy another car. I had a head turner that received just as many compliments as the Boxster. Oh and you get air bags unlike one of those old British cars with suspect electrical.
Porsche build cars that perform well but durability is not their concern. Most of their buyers will not daily drive and once the warranty comes nearer to the end they trade in for a new weekend toy. The Japanese figured out how to build for performance and daily use durability and we reward this by paying the Germans a big mark up instead of the Japanese.
05-29-2015, 05:28 PM
#16
I think Mr Lebowski has been effectively scared off.
05-30-2015, 08:51 PM
#17
thank you.. i promise to post pics of the car real soon. have a great weekend men
05-31-2015, 06:02 AM
#18
^^ excellent post. I've owned many cars over the years and none of them have been maintenance free after they started aging. These cars are getting on in years. I have around $9500 total invested in my daily driver, including the purchase price and accident repair which wasn't the car's fault. It's a lot of smile-inducing car for the money.
I look forward to the pictures.
| Thread Tools |
| Display Modes |
Hybrid Mode
