Old 05-13-2015, 11:43 AM   #1
Rburro2
rburro2's Avatar
Horn Blows fuse
I recently bought a 2000 Boxster. I noticed the horn didn't work. So I checked fuse B3 and it was blown. When I replaced the fuse the horn was as if someone was holding it on, without the steering wheel being touched, until the fuse blew again. Obviously there is a horn switch in the steering wheel. Is this hard to change? Or could there be a different problem?
2000 Boxster 2.7- First Porsche Owned
rburro2 is offline   Reply With Quote
Old 05-13-2015, 12:34 PM   #2
This is a common problem. Do a search on horn issues. It could be in the horn bracket up front, under the car. If I recall, the rubber gasket between the horn and the bracket can become worn and cause the horn to short out, and /or go off continuously. That would explain the previous owner removing the fuse. Good luck!
Old 05-13-2015, 12:59 PM   #3
Rburro2
rburro2's Avatar
Thank you I will check that out.
Old 08-03-2015, 09:32 PM   #4
Rburro2
rburro2's Avatar
I was able to fix the horn issue with some o-ring's I bought at Home Depot for about $5. I found the fix on you tube.
