This is a common problem. Do a search on horn issues. It could be in the horn bracket up front, under the car. If I recall, the rubber gasket between the horn and the bracket can become worn and cause the horn to short out, and /or go off continuously. That would explain the previous owner removing the fuse. Good luck!
