05-11-2015, 07:13 AM
Lug nuts. Any good deals?
Have you had success with a reasonably priced set of aftermarket set of lug nuts?
My summer wheels went on this weekend and those lug nuts are looking not so hot and aren't going on so smooth.
05-11-2015, 07:17 AM
1995 Porsche C4 Cab
05-11-2015, 07:40 AM
Need For Speed
Put caps on them. I have a set of these and they will not fall off. They look much better then the lug bolt too.
Porsche Black Lug Bolt Covers Caps All Models and Years Free Shipping Brand New | eBay
2003 Boxster S
05-11-2015, 07:56 AM
By the way, these are good to have in the frunk. They come in plastic. I have the metal one.
A hockey puck will work but these have the peg so you're in the right spot every time.
Lift Pad 97 04 Porsche Boxter 986 Jack Pad Adapter 1ea Blue Lift Puck Jackpad | eBay
05-11-2015, 11:40 AM
98 Arctic silver 986
05-21-2015, 03:56 AM
I also got mine from ecstuning. They seem to have reasonable prices.
05-21-2015, 06:14 AM
Originally Posted by KRAM36
I was using those for a while and I agree that they look good on the car. My complaint with them is that they are very hard to pull off unless you grease them in which case they come off too easily and you find the occasional one missing (or rather, don't find it). After a few on-off cycles they tend to split, at which point they just fall off. anyway. they are a good solution to ugly lugs, but they do come with a downside.
I'd like to find a reasonably priced set in stainless or titanium. I'd settle for satin-finish chrome.
'99 black 986
05-21-2015, 09:33 AM
I had spline drive set of those on previous car. I sprayed a thin rubber coating in the socket that would fit.
didn't work out too well. Kind of a hassle to keep clean.
I'd like to see a Ti color Krylon spray I could just hit the OEM lugs with.
05-21-2015, 11:09 AM
clean the old lugs with a wire wheel, apply a coat of spray paint to the caps and them apply a dab of grease to the threads of the bolts. quick easy fix for all of your problems. at 85ft/lbs of torque the will not come loose unless you take them off! there is no need to purchase a new set, they will only corrode like the old ones. by the way, the paint will come off after a while. all you need to do is simply repeat the process above. the can of spray paint will last longer than the car will. to me a $5.00 solution to replacing the lugs which will generally run about 10x more. just my $0.02
1977 Toyota Celica GT
05-21-2015, 11:18 AM
Saw a set of titanium bolts on E-bay last week for $225 that's why I recommended Raynor look into making some.
05-21-2015, 01:31 PM
Thanks for the Porsche Pucks
I ordered two, I had a set of generic pucks...but these are much better
05-21-2015, 02:29 PM
It thought it was 96# lbs for the wheels...where's my manuel.
