Old 05-09-2015, 07:16 PM   #1
stevendalia
Posts: n/a
Battery Tender
I've used a battery tender before on a car without electronics. Is it OK to use on my 2003 Boxster?
Old 05-09-2015, 07:25 PM   #2
CHRISP357's Avatar
Sure. C-tek is a good one.
CHRISP357 is offline   Reply With Quote
Old 05-10-2015, 07:03 AM   #3
mountainman's Avatar
got 2 boxsters and a C 4 hooked up to one. sure increases the battery life.
Old 05-10-2015, 12:24 PM   #4
stevendalia
Posts: n/a
Battery Tender
Sounds good. Where and how have you guys been threading the cable?
Old 05-10-2015, 12:27 PM   #5
Wallace River's Avatar
I just sit it in the front seat floor and plug it in to the cigarette lighter.
The name's Ian....now a former owner.....sold my 2000 Speed Yellow Base to its new owner in Nova Scotia.
Wallace River is offline   Reply With Quote
Old 05-10-2015, 12:32 PM   #6
Got a permanent pigtail hooked to the battery posts and barely sticking out from under the hood between the wipers. Cable from the battery tender is run across the ceiling and dropped down in the precise spot that I want the car parked and when I pull in I know just where to stop. when I exit the car I plug in the cable and it is good to go until I take it again. I have a 4 bank tender, one for each Porsche and one for the truck.
Old 05-10-2015, 06:51 PM   #7
stevendalia
Posts: n/a
Battery Tender
Both very practical ideas. Thanks.
Old 05-10-2015, 07:21 PM   #8
The technology for what used to be called trickle chargers and then float chargers has changed. The new device includes a sequence to de-sulfate the battery and automatically adjusts the rate of charge.
Here is one example that I use:
BatteryMINDer Model 1510
BatteryMINDer 1510 | 12 Volt Maintenance Charger with 10 Year Warranty
There are other models and other brands that do the same hi-tech battery care.
Old 12-23-2023, 01:07 PM   #9
[QUOTE=Gelbster;449161]The technology for what used to be called trickle chargers and then float chargers has changed. The new device includes a sequence to de-sulfate the battery and automatically adjusts the rate of charge.
There are other models and other brands that do the same hi-tech battery care.[/QUOTE
Just ordered the 1510 for my 2002 Boxster S, hopefully one less thing to worry about this winter.
DanD04 is offline   Reply With Quote
