Old 04-23-2015, 11:21 AM   #1
Heiko's Avatar
Originally Posted by CrisZenithBlue View Post
yeah i'll give that a try most likely Friday and update.
question: no matter what position i put the vents in, the dash ones always blow air. is that normal? i mean i can set them to windscreen only or foot well only and i still have air coming out from the main dash vents. could that be a sign of the motor not working properly?
not that its a bother..
So that clicking sound is coming from the stepper motors trying to adjust the vents... its either the gears or something else jammed up and that's why they make that knocking sound... that's why your vents are always blowing out the dash vent... that should change when you set to defrost or floor vent.... in auto mode those regulators automatically redirect air where required so it constantly adjusts itself (but obviously that's not working)
Not a fun job pulling the dash out to get at those regulators!!!
Previously owned:
Old 04-23-2015, 11:49 AM   #2
CrisZenithBlue's Avatar
oh crap.. any chance thats a DIY? i"m a patient guy if it requires more time than specialized skills. would it most likely require replacing the regulator?
i can probably live with it. but will it get worse and eventually completely break?
CrisZenithBlue is offline   Reply With Quote
Old 04-23-2015, 12:43 PM   #3
Heiko's Avatar
Taking the dash out is requires some skill but more patience.... steering wheel has to come out (careful with the clockspring mechanism) if you attempt this yourself... If you have the time and are handy with tools, you can probably do this yourself. Just take lots of pictures and remember where all the screws go... its quite a mess of parts!
The little adjuster motors look something like this... you'll have to determine which one is causing the trouble or what's jamming it up... unfortunately there is no easy access to these especially for troubleshooting any jams etc.
http://jdmspares.pairserver.com/CARS/J046-Porsche986Boxster/P1340131.JPG
Previously owned:
Old 04-23-2015, 01:22 PM   #4
oh boy.. doesnt sound like fun but i might jump on it myself.
i recently replaced the steering wheel so that shouldnt be so hard but what clockspring mechanism are you referring to exactly?
Old 04-23-2015, 07:32 PM   #5
Heiko's Avatar
The clock spring is in the steering column... you'll see it when you take the steering wheel off.... just careful it doesn't come apart, it looks like this..
http://photo.nurburgringautoparts.com/2014Q1/104753/104753_320.jpg
hopefully you can try determining which regulator it is before you end up pulling everything apart... best of luck and keep us posted.
H
Previously owned:
Old 04-24-2015, 05:35 AM   #6
H
ah ok. i know this piece. it felt very flimsy when i took the steering wheel off. will be careful with it if it comes to that!
thanks a lot for all your input guys! weekend is coming up and i will have a go at it and report back.
