Old 04-10-2015, 01:45 PM   #1
boxster roof riddle (disco dance)
when closing my roof, just 3" before it touches the windshield top, my roof does a little disco dance!
it stops and goes back 1", then forward 1", then back 1", etc etc etc while I am holding the top up button
same deal for the top down button
I rap on the button several times until I can get it going in the down direction, then change to up switch and it closes
I have tested the switch and it tests just fine
has anyone seen this?
boxster Bob is offline   Reply With Quote
Old 04-10-2015, 02:37 PM   #2
Fintro11's Avatar
I'm sorry, but it seems your car has come down with disco fever !
Old 04-11-2015, 09:40 AM   #3
I don't have the answer for you, but check the rods that operate the top. They have the plastic cups on one end and bolt into a lever arm on the other end. The other end of the lever arm moves the clamshell cover. If it is not doing 'dancing' with the front of the soft top, I would really suspect those pushrods even more. I suspect they are out of adjustment or have some worn bushings. . See if you can get some one to operate the roof while you watch those linkages.
Old 04-11-2015, 09:18 PM   #4
Pdwight's Avatar
Try a different relay
The roof relay is not just a mechanical DPDT relay
