Old 03-27-2015, 09:08 AM   #1
Help please. I need an accurate measurement flange to flange.
Hello I just got (dead) boxster and I want to bring her back to life.
I need the measurement from cv flange to cv flange across the transmission. From the Cv mounting surfaces.
Thx. Matt
Sassmatt72 is offline   Reply With Quote
Old 03-27-2015, 11:52 AM   #2
Sassmatt72,
First of all, Congratulations..!
But you should provide more details like your car is a 5speed, 6speed or automatic transmission, as all of these are (I believe) different in size.
Also with a picture of your new car you will get more cheering... :-)
Regards,
Old 03-27-2015, 08:08 PM   #3
98 5spd, very dead engine....
so how do i put a picture on here???
I found out it dropped a valve, shattered a piston, and cracked a cylinder.
but one head, 4 cams, 5 pistons, (maybe) the rods and crank, and all the exterior motor parts are fine... lol
anyone need 2.5 motor parts?
m
Old 03-27-2015, 08:09 PM   #4
Old 03-28-2015, 01:24 AM   #5
Need For Speed
KRAM36's Avatar
Curious, year and how many miles on it?
2003 Boxster S
Old 03-28-2015, 05:30 AM   #6
jsceash's Avatar
Interested which transmission your looking at.
The 5 speeds hubs are slightly offset to DS, and have a longer shaft on the Passenger side. 6SPD's are equal length actually the same axle.
Old 03-28-2015, 05:43 AM   #7
Beginner
Jamesp's Avatar
m
You might. 2.5's are inexpensive on Ebay. The parts are not. Depending on your situation, you might strip your existing 2.5 of expensive parts, put them in a box, and grab yourself a used 2.5 and pop it back into the car. And then three's always the temptation for more horsepower with a bigger engine, but that can be more complicated.
2003 S manual
Old 03-28-2015, 07:50 AM   #8
hi all, it's a 98, only 67k on it, must have floated a valve dropping the keepers...
its a 5 speed. the whole car is really clean, she must have been a garage queen (till she died) last reg is 8 years back.
I'm seriously contemplating a subaru engine transplant (cue the flame war).
I've done 4 subie motors into vanagons in the past, so I'm well versed in the basics, wiring and suppliers....
the best I've heard so far for a 2.5 P motor (used no guarantee, but a video of it running) is in the 1500$ range for a long block... wit a 6 month guarantee from local used place is 3500-5500...
any ideas, this car is too nice to part out. (and I really want to drive it through the twisties.
Old 03-28-2015, 08:13 AM   #9
The Radium King's Avatar
kpaz (precision chassis works) has a kit.
Old 03-28-2015, 08:31 AM   #10
subie....
Yup I've been looking at that one for sure. He does incredible welds and his ideas look great.
I'm in CA so the carb/smog cert might be hard that way, but not un-doable?
But 2100 for the adapter +800 for the cradle.... and CA law says a motor and trans are "supposed" to be transplanted together...?
Has any of his been CA registered?
Old 03-28-2015, 10:16 AM   #11
Thx. Matt
Not sure if this will help, but ballpark is 10.5", eyeballing it with tape measure.
spendy is offline   Reply With Quote
Tags
cv's , flange. , transmission
