Old 03-27-2015, 07:27 AM   #1
Boster plastic trim interior
I have a 2001 Boxster with plastic woodgrain trim that is disintegrating. Is there a replacement for these pieces and if so, where? The pieces include a thin strip across the underside of the passesnger side dash with the term "airbag, the area around the speedometer and a piece on each door near the handle.
Thanks, Larry
022520 is offline   Reply With Quote
Old 03-27-2015, 10:06 AM   #2
Suncoast has the sport silver version: Dash Trim Strip Set in Sport Silver:Suncoast Porsche Parts & Accessories
Although it says professional installation - so I'm guessing this isn't going to be easy
mack73 is offline   Reply With Quote
Old 03-27-2015, 10:19 AM   #3
98 Arctic silver 986
tommy583's Avatar
Wow $250 for that? If I were you I would just take it off and paint it. I am going to do that to mine when I get the car out of hibernation. There are a few how to guides on here. Do a search for dash trim and you should find something.
Old 03-27-2015, 11:22 AM   #4
M4SGK1986's Avatar
I removed and repainted mine the same color as the car and as Tommy notes there are a few threads on how to do this. The trim under the air bag was the easiest to remove, 7 torx screws if i remember correctly and two torx screws for each trim either side of the steering wheel. my car has a glove box so i removed that to gain access. However the ones either side of the wheel were more tricky, i had my head in the foot well and an extender on my screw driver!
here is the tread i used Help required with interior trim!l
Steve
_________________________
2004 Boxster 2.7 - Atlas Grey
M4SGK1986 is offline   Reply With Quote
Old 03-27-2015, 11:26 AM   #5
Unfortunately, I cant paint anything because the pieces are crumbling. I need to find replacement pieces and then figure out how to put them on. Looks like the original pieces were glued on
Old 03-27-2015, 11:48 AM   #6
M4SGK1986's Avatar
Ah right, erm thats an interesting one, maybe an owner in the past removed them and then just stuck them back on. do you have any pictures showing the crumbling?
Steve
Old 03-27-2015, 12:48 PM   #7
tommy583's Avatar
Get a hold of itsnotanova in the parts for sale thread. I'm sure he can set you up no problem.
Old 03-27-2015, 01:08 PM   #8
Need For Speed
KRAM36's Avatar
Id like to see some pictures of this too.
2003 Boxster S
Old 03-28-2015, 06:30 AM   #9
Are you sure you don't have a stick on aftermarket wood grain kit installed? I recall seeing those advertised years ago. If so, you might be able to just peel it off, remove the glue or tape with WD40 or alcohol and be back to the original plastic.
linklaw is offline   Reply With Quote
Old 03-28-2015, 07:25 AM   #10
Chuck W.'s Avatar
Agreed... great guy, honest as they come and great prices.
http://986forum.com/forums/boxster-parts-sale-wanted/52469-parting-out-whole-lot-boxsters.html
1995 Porsche C4 Cab
Old 03-28-2015, 03:43 PM   #11
I would like to see the crumbling also. If it is an aftermarket stick on, Naptha also works well to remove the glue. If you need spares, I can't recommend Woody enough!
Defectfully
Patrick
Hogosha is offline   Reply With Quote
