Old 03-23-2015, 09:20 AM   #1
Registered Boxster abuser
healthservices's Avatar
Being a tight wad.... rear track arm
Does someone make a replacement bushing I can install to repair a worn out rear track arm?
Old 03-23-2015, 10:35 AM   #2
Old 03-23-2015, 12:00 PM   #3
Hello Health,
I have seen here, people mentioning about a company that sells suspension components (on exchange basis) that have new bushings installed on them, unfortunately I cannot remember the name...
Regards,
Gilles
Old 03-23-2015, 08:14 PM   #4
Porsche Rebuilt Control Arm - Rear Track Arm: Steering and Suspension &amp Control Arms and Related Parts
They are about as expensive as the replacements. I just figured if there was a way to put the bushing in myself it would be even less expensive.
Old 03-23-2015, 08:26 PM   #5
I found one manufacturer that sold replacement bushings - they were $120 - hardly worth the savings.
Old 03-24-2015, 01:39 AM   #6
Pdwight's Avatar
Bushing
I just replaced the track arms on my S, the arm uses a ball joint...I cant see how a bushing can do the same job ??
You can take yours off and "peen" the rolled flange to tighten one up....not sure how long this will last...but you could try it and see.
Boxster Control Arm Repair - 986 Boxster Suspension, Brakes, and Wheels - RennTech.org Forums
Old 03-24-2015, 10:52 AM   #7
Ah, I saw the version where the joint was replaced with a bushing as seen in the above post. I guess the arm is machined to allow a bushing in there.
