Old 03-08-2015, 03:14 PM   #1
Max Rim Width
I have a 97 Boxster Base. Staggered rim setup of 7" front, 8.5" Rear. Does anyone know the maximum width Rim I can put on both front and back. Do they have to be staggered? Or, can you 4 same size rims?
1997 Boxster! (Tiptronic)
brjak is offline   Reply With Quote
Old 03-08-2015, 05:26 PM   #2
Need For Speed
KRAM36's Avatar
I know there is some kind of wheel restriction to the 97 986, think it had to do with the wheel diameter, but a 986 can go 8.5" front and 10" in the rear no problem with stock suspension.
If you want the most out of the car, yes you have to go staggered.
2003 Boxster S
Old 03-08-2015, 06:29 PM   #3
I am running 225/40zr18 up front and 285/30/zr18 in the rear and it looks great.
Redboxs is offline   Reply With Quote
Old 03-08-2015, 06:32 PM   #4
I attempted to put some 11" width wheels from a 996 on my 986, the wheel hit the rear shock. I could start threading 2 of the wheel bolts but the other 3 wouldn't catch. I think with some 20 or 25mm spacers, they would fit but then I'm not sure how much they would stick out of the fenders. Not a bad thing if you like the mexi-flush look...
dijinn is offline   Reply With Quote
Old 03-08-2015, 06:42 PM   #5
biglimited's Avatar
Telling only tire widht doesnt give you enough info about how wide wheels. ET numbers are needed too, of course. And after these you can alter the camber front and back and use even wider wheels. And still you can put undersize tires to wide rims if the rim sticks out of fender. Nuff said?
Still waiting for first correct numbers.. i have 10x18 et 40 back this summer with 255/35
2004 Boxster S manual
biglimited is offline   Reply With Quote
Old 03-08-2015, 07:25 PM   #6
Porsche service bulletin says on the 97 nothing bigger than 17"
Old 03-08-2015, 08:46 PM   #7
Need For Speed
KRAM36's Avatar
You could go 275/35R18 on the 10" rim, but you would want to match the tire diameter the best you can so you would want 235/40R18 at the front.
2003 Boxster S
Old 03-09-2015, 04:17 AM   #8
biglimited's Avatar
Yes i know but with 10x18 et 40 that tire is too wide... 225 and 255 match optimally when 40 and 35 profiles
Old 03-09-2015, 09:43 AM   #9
I run 19x8.5 +15 in the front with 215/35 and 19x9.5 with +10 in the rear with 225/35. Running it lowered 1.5 inches and rolled fenders though. I'm sure with higher offset you can achieve a much wider wheel. I was planning on 18x10/18x11 with a higher offset as my next set of wheels.
Holy_Shift_986 is offline   Reply With Quote
Old 03-09-2015, 10:17 AM   #10
Need For Speed
KRAM36's Avatar
Too wide for what?
Tyre Size for Rim Size/Width Calculator - What's the best tyre size for my rim?
2003 Boxster S
Old 03-09-2015, 02:52 PM   #11
biglimited's Avatar
Sorry my english.. i meant that with 275 et 40 would scrub my arc/fender(?). With 255 i can get away not touching these arches/fenders...
Old 03-10-2015, 07:11 PM   #12
Need For Speed
KRAM36's Avatar
That's interesting. A 10" wide with with a 40 offset is supposed to fit perfect even with a 275 tire.
2003 Boxster S
Old 03-12-2015, 05:11 PM   #13
I know many have helped. But, can someone confirm these rims will work on my 97 986.
FRONTS: RS 773
Offset: ET:50
Porsche Part# 993.362.134.55
FR-4400N
Bolt Pattern: 5x130
REARS: RS721
Offset: ET:65
Porsche Part# 993.362.140.50
FR-5750N
Bolt Pattern 5x130
