Old 04-21-2016, 07:13 AM   #1
Joe B's Avatar
I put an Exide Edge AGM battery in my 2003 Boxster because it works great in the cold (it gets really cold here, -20° F or lower) and I sometimes leave the car for weeks at a time in winter. I either disconnect the battery (I remove the frunk latch first), or I leave my CTEK charger hooked up. No problems and both the battery and charger work great! When the 2 batteries in my boat and the 2 in my diesel truck wear out, I will buy AGMs for them too!
Also, I love the blue color!
Battery Chargers - CTEK Battery Chargers MUS 4.3 POLAR
Old 04-21-2016, 02:45 PM   #2
BirdDog's Avatar
I have an 01 S and use the Porsche branded CTEK charger via the cigarette lighter port. I would have bought the CTEK branded charger, but got a better deal on the slightly less capable Porsche branded one.
I upgraded my cigarette lighter port to smaller standard sized port that Porsche switched over to in 2003. Much better when plugging things like GPS, iPods, and chargers in (no more loose plugins). Pretty sure I bought the kit from Suncoast, but Pelican should have it as well. You shouldn't need it though for a 2005.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 04-21-2016, 03:28 PM   #3
"50 Years of 550 Spyder"
10/10ths's Avatar
I just bought a battery and charger.....
...bought and installed this battery:
NSB-AGM94R (L4) Battery****| NorthStar Battery
and keep her charged through cigarette lighter with this charger:
CTEK Multi US 7002 - CTEK Battery ChargersCTEK Battery Chargers
Works like a charm.
Highly recommended.
Good luck.
Old 04-21-2016, 06:55 PM   #4
schnellman's Avatar
Ctek schmetek
I bought the CTEK battery maintainer at my local stealership so it says "Porsche" on it. Maybe it cost twice as much, but I'm sure it works ever so much better than the identical one with CTEK on it. I've been using it through the cigarette lighter and the battery is still working fine after seven years.
Old 04-22-2016, 01:14 PM   #5
The trick with CTek is to get the "Bundle" I linked above.Otherwise you'll get nickel & dime-d with the accessories.
I bought mine for $85 from "Jet"
