Old 02-09-2015, 05:38 AM   #1
Artist, 986S tinkerer
NewArt's Avatar
Coolant leak up top?
Pulled the starter for maintenance and what do I see? A small sea of green on top of the engine near the oil cooler! I will need to investigate further but off the top, any obvious spots to check?
Thanks.
Old 02-09-2015, 06:32 AM   #2
the oil cooler for starters...
"Cool Prius!"
- Nobody
Old 02-09-2015, 08:30 AM   #3
1999 base
Meir's Avatar
looks like you will need to replace the O-rings for the oil cooler.
not too complicated.
Old 02-09-2015, 09:26 AM   #4
NewArt's Avatar
Hopefully it's just that! I don't suppose that the cooler itself breaks. I figured a hose or something.
Old 02-09-2015, 10:43 AM   #5
NewArt's Avatar
Is it necessary to drain the coolant in order to remove the oil cooler?
Old 02-09-2015, 02:12 PM   #6
1999 base
Meir's Avatar
when i replaced the O-rings on my car as a preventive maintenance, i drained the coolant.
my assumption was that the cooler will be full of water, and you don't want to mix it with the oil.
that's how it looks when the cooler is removed.
and the O-Rings
Old 02-09-2015, 03:31 PM   #7
NewArt's Avatar
Thanks for posting the pictures! I can easily see the reasoning behind a coolant drain.
Cheers!
