02-09-2015, 10:40 PM
Brake Fluid Change
Hi guys,
I recently did a brake fluid change on my sister's BMW. The fluid was about 2 years old. I really had a hard time telling when the old fluid had been pushed out because the color didn't drastically change. The old fluid was slightly yellow, and the new is almost clear. I couldn't tell when it changed from yellow to clear. I did it four times on four wheels and still wasn't 100% sure that all the old fluid had been replaced. I think blue brake fluid is not allowed on the market anymore, so anyone has any tips for me? I'm about to do it on my Boxster.
02-09-2015, 10:52 PM
I had the same problem, it was really hard to tell when the old fluid was out
I found a post somewhere where it listed the volume in the lines, don't remember where
IIRC, it was around 6 oz for each rear and 4 oz for the fronts each
I based my flush on volume.
maybe someone can chime in on this
02-10-2015, 10:25 AM
Originally Posted by hancock1701
Hi guys,
>> Yeah, this is your government at work. Thanks for that...
02-10-2015, 03:58 PM
Alternate gold with clear. As you can see, the gold (right) is very yellow.
Or go racing for a year, then the gold turns brown (left).
02-10-2015, 04:00 PM
Originally Posted by thstone
Alternate gold with clear. As you can see, the gold (right side) is very yellow.
are you sure that is not your oil on the left?
