Old 01-21-2015, 07:24 AM   #1
78F350's Avatar
Scrapping an engine. Anything worth saving?
I am about to scrap a 2.7 engine that had a broken #2 rod, piston, and cylinder. The whole engine was full of debris. I am planning to keep the intake, harness, various sensors, sump pan, and accessory bolts. (That is probably too much already) Is there anything else worth saving? Is there anything anybody needs?
Old 01-21-2015, 02:55 PM   #2
My first thought was to save the Cam chain tensioners. But if the engine was full of debris, they might be toasted.
Old 01-21-2015, 02:57 PM   #3
78F350's Avatar
I finished pulling the engine apart today. It was already bad when I bought the car as salvage, so I don't know the circumstances of it's demise. I did discover a bolt, that looks like a rod bolt, floating around the case that was not missing from any of the rods. It appears to have left a few good impressions:
Other than that, some of the coolant had turned into strawberry Jello.
As for parts, I hear that the IMS can make a good lamp. Anyone want it?
Old 01-21-2015, 03:24 PM   #4
78F350's Avatar
Thanks. They actually look good to me. There was lots of debris, but it hadn't been floating around for long. It was apparently a pretty catastrophic failure.
Old 01-21-2015, 03:29 PM   #5
BYprodriver's Avatar
I'll take the IMS
Old 01-21-2015, 03:49 PM   #6
I'll take the IMS
You should keep all the bolts from your engine except what shouldn't be reused for rebuilding.
Maybe I can trade you something for your IMS & shipping costs.
Old 01-21-2015, 04:44 PM   #7
78F350's Avatar
It looks like your PM inbox is full. Shipping should be just under $20. If you have the license plate frames still, I'll do that swap and call it even. ?
Old 01-21-2015, 05:05 PM   #8
I cleared out some of my PM's. Yeah that sounds like a good swap.
Old 01-21-2015, 05:35 PM   #9
flaps10's Avatar
78,
I'll take your M6x35 screws used to hold the lifter carriers in the heads. I really only need 1 screw, but I'll take them all just so you're not stuck with a random pile of junk.
Old 01-21-2015, 05:59 PM   #10
Save the oil filter housing. I don't need it, but I've had a few people ask me for one.
Woody
Old 01-22-2015, 07:37 AM   #11
78F350's Avatar
Shipped cheap with FedEx, along with the second item. That PM inbox filled up again.
I dropped all of them from one side in a bag, and threw in a few random bolts. I'm thinking USPS Small Flat Rate Box. Want any other small bits of engine in there? PM me an address.
Thanks. Sounds like a good simple eBay item.
Old 01-22-2015, 07:39 AM   #12
78F350's Avatar
What about the Variocam mechanism? Do those ever need to be replaced/worth holding on to?
Old 01-22-2015, 07:42 AM   #13
Yes keep those if not damaged.
Old 01-22-2015, 11:12 AM   #14
Retroman1969's Avatar
I don't need anything of have anything to add. I just wanted to say wow! That thing must've made a hell of a noise when it went!
You ever figure out where the bolt had come from?
Old 01-22-2015, 12:51 PM   #15
78F350's Avatar
I can't find any spot that it was missing from. The engine had about 120K miles on it, so I don't think that it came from the factory with a 'spare' bolt in the case. It remains a mystery. (Now I really want to drop the pans on my good engines just for peace of mind.)
Bob, as noted in the pm, here are pics of the oil pump. Obvious scoring around where the gears rotate, but to me it all looks functional. I will give it a quick run in the parts washer at my office if you want it - I just noticed the dog hair on the gears in the pic :
Old 01-23-2015, 01:52 PM   #16
78F350's Avatar
In conclusion...
Unless you have an intact core there isn't much of value to a grenaded M96.
Bolts and accessories can be useful for future maintenance.
It was well worth my time to take it apart for the education. I have a much better understanding of the design and function of these engines now.
As for the scrap, I dropped off two stripped 4cyl Integra blocks, an Accord V6 engine, and the stripped out 2.7 M96. My total was about $160 of which probably 1/3 was from the M96. The case halves make pretty easy "clean aluminum", but most of it was best left as mixed. Not much of a business venture, but I got some real estate back in my garage.
Old 01-23-2015, 02:07 PM   #17
The Radium King's Avatar
Old 01-23-2015, 04:50 PM   #18
com3dorm3's Avatar
Ha!
Let me see if that flies with my wife if I put a nice bouquet of flowers on top lol
2000 Boxster S
com3dorm3 is offline   Reply With Quote
