Old 12-26-2014, 08:19 PM   #21
Originally Posted by 99 Boxcutter View Post
My 986 doesn't have a cigarette lighter and I was going to buy THIS generic $3 lighter from China rather than pay $35 for the OEM.
Will it work, or did Porsche make it to where you MUST HAVE their lighter?
That is one flashy butt sparker
OEM is 22mm.
Old 12-26-2014, 10:24 PM   #22
Pdwight's Avatar
I have a base 2.7 and would like more power. I know a guy who will give me a 3.8 from a 991 GT-3 Cup car for free. Is this a drop in replacement? Can I run the stock ECU?
Take it regardless if you install it or not.
Old 12-26-2014, 11:14 PM   #23
Sometimes after sitting for a while my car puffs a bit of blue smoke when I start it. What could be wrong? Do I need a new engine?
Also, my check engine light is flashing. Is this because of the blue smoke? Is it ok to drive the car until I can get it looked at?
'99 black 986
Old 12-27-2014, 04:33 AM   #24
If the CEL is flashing, i would be wary of even running the engine, let alone driving it, it could indicate something catastrophic! Use a diagnostic tool like durametric if possible to pull the codes and post here for advice, or have the car towed to the closest shop to be looked at by a professional. Good luck!
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 12-27-2014, 05:46 AM   #25
husker boxster's Avatar
I had my Porsche out for a nice drive yesterday, runnin sweet as you please. Then I heard this awful metallicy sound and the engine died. I tried restarting it and it won't fire - just that horrible sound. Must have tried it 20 times - nothing.
Think I should try it again after letting it sit overnight?
1989 928 S4 5 spd - black
Old 12-27-2014, 06:03 AM   #26
I am my own mechanic....
Timco's Avatar
'08 VW Touareg T-3 wife's car
Old 12-27-2014, 07:03 AM   #27
I realized that after I posted and scrolled up
Happy holidays!!
Old 12-27-2014, 08:03 AM   #28
BIGJake111's Avatar
So I was going down the road and my ims, aos, and water pump all went out at once, I didn't want a tow though so I eased it home. Do you think this hurt the engine?
Old 12-27-2014, 08:26 AM   #29
What's are codes? Do you think my truck would be able to pull them or are they really big? I've got 4WD if that helps. Where do I pull them to?
'99 black 986
Old 12-27-2014, 08:27 AM   #30
Timco's Avatar
The jacking points are just under the front & rear bumper with a farm jack, eh?
Old 12-27-2014, 08:35 AM   #31
No, you screw the tow hook into the front bumper to use as a jacking point. In the rear you just stick the tongue of the jack in the exhaust pipe and lift it that way.
'99 black 986
Old 12-27-2014, 08:54 AM   #32
Timco's Avatar
Take off....
I knew the bumpers were rubber so I used the tops of the wheel wells. Not a good spot to jack from. :/
Old 12-27-2014, 09:39 AM   #33
Well yeah, dumbass - how do you get the wheel off with the jack in the way??
'99 black 986
Old 12-27-2014, 09:54 AM   #34
still plays with cars...
BoxsterSteve's Avatar
Do I have to buy specialty muffler bearing grease from a Porsche dealership, or can I use the generic stuff that they sell at Pep Boys?
I'm only asking because I've been using generic headlight fluid for a couple of years with no ill effects and want to save a couple of bucks to buy a left-handed steel stretcher at HF this month...
Six speed 2000 Boxster S
Old 12-27-2014, 10:24 AM   #35
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by BoxsterSteve View Post
... and want to save a couple of bucks to buy a left-handed steel stretcher at HF this month...
Be careful with those HF steel stretchers. I heard that they bought a bunch of expired ones from a UK distributor and converted them to left hand drive, by re-drilling and bolting the handle on backwards.
Old 12-27-2014, 11:21 AM   #36
Timco's Avatar
You know, I thought about the damage to the fender, but didn't even consider this......
Old 12-27-2014, 11:35 AM   #37
Pdwight's Avatar
Yes there is a special grease , but turn signal lubricant will work in a pinch
Old 12-27-2014, 08:24 PM   #38
Olde Tyme Sport Cars
history19's Avatar
Has anyone ever had their instrument cluster back lights go out? I've checked the fuses and all are good. Is there a relay the lights are fed through? My next step is to remove the dash. Oh and BTW, I did try the manual intensity switch...I'm baffled.
history19 is offline   Reply With Quote
