Old 12-05-2014, 12:05 PM   #1
batshapedheart's Avatar
Let's play the game of "what the heck is wrong with my Boxster now?"
Here's a video clip with the sound it just started making at start up.
Any input appreciated
http://youtu.be/Nmy_UD6xU90
2002 Boxster 2.7
batshapedheart is offline   Reply With Quote
Old 12-05-2014, 12:09 PM   #2
You have either got something stuck in your engine compartment fan, it's failing, or the SAI pump.
Old 12-05-2014, 12:40 PM   #3
Its the SAI pump. Theres a fix if you search on renlist which involves removing the pump, taking it apart and greasing the bearings in the pump. Easy fix. The pump is pretty pricey.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-05-2014, 04:18 PM   #4
Beginner
Jamesp's Avatar
You'll need to fix the existing pump soon or you'll fry the bearing and have to replace the pump.
2003 S manual
Old 12-05-2014, 04:23 PM   #5
jsceash's Avatar
Your running a circular saw in you other hand. if not,
I'm going to agree with the others your air pump is biting it.
Old 12-05-2014, 05:15 PM   #6
kk2002s's Avatar
I had a less severe whine from SAP
Pulled it opened up got to bearing
Use a basic hand grease gun with a needle adaptor to get grease behind the seals
It another sealed bearing that losses it's grease. Sound familiar
Seal Grey
Old 12-06-2014, 01:18 PM   #7
If you examine the pump bearing carefully ,it should have a generic part number on it.It is usually 4 digits followed by letters. You can then search for a similarly dimensioned bearing or even upgrade to a higher temperature rated bearing. According to this link you can get a 1/4" Timken replacement inexpensively:
http://www.audiworld.com/forums/a6-s6-c5-platform-discussion-7/writeup-2-7t-secondary-air-injection-sai-pump-rebuild-1727056/
If you remove the bearing and take it to your local bearing store, you may even be able to get a ceramic bearing replacement. You just need i.d.,o.d. and width.Then decide what type of seals 7 grease you want. The bearings come in various grades(ABEC is common) but for this low stress application ,the utility grade is probably adequate.
Please let us know what you find and what you do to repair the pump.
