Old 11-22-2014, 09:56 AM   #1
Fighting with air/oil separator
Armed with Pelican and Pedrosgarage DIYs I jacked my 97 up and crawled under to dislodge and swap ou a faulty oil separator. Geez, it took me 20 mins just to locate it from the underside and it seems nearly impossible to get to it laying on my back.
Did I miss something? Do I need to remove the bottom panels or come in through the wheel well to get at it?
It's cold in the garage and I don't want to freeze to death trying to figure it out.
Thanks.
Jb
theboogins is offline   Reply With Quote
Old 11-22-2014, 10:12 AM   #2
Did mine for the first time a month ago. Yes, it was a bigger pain than I expected. It was easier underneath when I got the O2 sensor wires out of the way by unscrewing that bracket and swinging them to the side. Not sure if that's the same on a 2.5 (I have 00 2.7).
If you don't have one, get one of these. I wasted a couple hours trying to get the last clamp back on without one. Got so freakin' close everytime. Then done in one shot when I finally got this for 15 bucks or so at an auto parts store.
CraigM is offline   Reply With Quote
Old 11-22-2014, 10:21 AM   #3
Oh, and my arms were twisted around in some funky ways up there, but it is possible to do without removing anything major.
Old 11-22-2014, 11:23 AM   #4
There's a nice write up by Brad Roberts a few years ago.
Air/Oil Seperator write up?
http://986forum.com/forums/general-discussions/18090-air-oil-seperator-write-up-4.html
See if you have a new hose with the new AOS (See Attached pic). If you do have a new hose just cut the old hose instead of trying to loosen the clamp. This will save you a lot of time and having to buy a special tool. When reinstalling I used a standard clamp and used a socket to tighten.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
Old 11-22-2014, 06:18 PM   #5
AOS replacement tips
clickman is online now   Reply With Quote
