Old 11-21-2014, 02:55 PM   #1
Durametric Troubleshooting of P1124,1126, and 0130
After much searching I have not found any clear answers. The car is running fine and I did a quick scan prior to the smog test. The P1124/1126/0130 came up, no CEL. After looking up the codes I hooked up the Durametric with the following results that I believe are most relevant to the situation.
The 02 sensor ahead of the cats, both banks, both look very sloppy. Sharp (up/down) and then slow reaction to both the high or low voltage. No real pattern just a choppy graph, not at all like the typical wave pattern I have seen....and I even played with the sample rate (fast/slow) and nothing smoothed the curves. In addition the values went below .1 on many occasion.
To ensure I am not missing any other "root" causes (e.g. air leak or fuel delivery issue) I checked the FRA and TRA (which best I can tell is the German version of Short and Long term Full Trim. I believe these are "normal" and do not indicate either a fuel delivery and intake air leak. The values I get are:
FRA/FRA2 - 1.03 (steady and the same for both)
TRA (.13) and TRA2 (.11) both steady
My conclusion is that it is simply the upstream O2 sensors and there is no other root issue. Any other thoughts on conclusions or other sensor I should have monitored? Thanks!!!
runjmc2 is offline   Reply With Quote
Old 11-21-2014, 03:32 PM   #2
It really helps if you tell us what the fault code descriptions are. Eg. p1111 signal implausible.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-21-2014, 06:26 PM   #3
It is a '97 manual with 112K mi., again is running fine and there is no CEL yet. Though I have seem some inconsistencies, I believe the error code descriptions are:
P0130 - Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Intercore Short Circuit or Limited
P1124 - Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Rich Threshold
P1126 - Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold
Old 09-08-2015, 04:12 PM   #4
epapp's Avatar
Almost a year old bump...did new oxygen sensors resolve your issue?
epapp is offline   Reply With Quote
