Old 11-18-2014, 01:11 PM   #1
Giller's Avatar
Re-Tighten Lug Nuts?
Noob question here. I had my winter tires installed on my DD (my little Box is now hibernating). They put a sticker on my windshield that said to re-tighten the lugs after 400 kms. Never done that before in all my years of winter tires. Is this true?
Old 11-18-2014, 01:24 PM   #2
recycledsixtie
recycledsixtie's Avatar
It is definitely a good idea to put the torque wrench on the nuts (or get somebody else to do it) at that interval. I still remember the sound of a loose nut rattling in a hub cap years ago. Not a good sound.
Cheers, Guy
Old 11-18-2014, 02:46 PM   #3
Sounds like its just a cya sticker they put on every car. Usually the problem is that the bolts are way too tight because the shop uses air tools. But i would take off each bolt, make sure it id lubed to spec and tighten wiyh a torque wrench.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-18-2014, 02:57 PM   #4
woodsman's Avatar
Now they're not responsible... YOU are! And while it's the norm on transport trucks, I've not heard of it with cars before.
Old 11-18-2014, 03:01 PM   #5
There Is No Substitute.
rick3000's Avatar
I always tell the tire shop to not use an impact wrench, after a shop destroyed one of my hubs. (On the bright side I got a brand new hub installed by the dealer at their expense.)
I check the torque on the lugs after 100 miles, whenever the wheel has been removed. It's just a precaution. I agree it sounds like a CYA sticker for liability reasons, their insurance company or lawyer must be a very cautious car guy.
You don't want this to happen: https://www.youtube.com/watch?v=kyMDNzhfwn0
Old 11-18-2014, 03:53 PM   #6
I always re torque the lugs after a week or so every time I changes wheels.
Chris
'86 944, manual steering, a/c delete, 944Max chip
'87 951, K27, LBE, Turbo S brakes, Koni Yellows, Weltmeister sway bars / strut brace, LSD, full cage, OMP race seats
'01 Boxster - Seal Grey / Black / Black, Litronics upgrade / de-ambered
crooster is offline   Reply With Quote
Old 11-18-2014, 04:05 PM   #7
still plays with cars...
BoxsterSteve's Avatar
This.
It's just peace of mind. I found one that loosened off once. I'd hate to have a wheel pass me on the highway...
Six speed 2000 Boxster S
Old 11-18-2014, 04:22 PM   #8
Pretty soon there will be CYA stickers on everything!
I always recheck the torque on my wheels after a shop has worked on any of my cars. I simply don't trust them.
Old 11-18-2014, 04:38 PM   #9
What is the correct torque setting?
Old 11-18-2014, 04:42 PM   #10
rick3000's Avatar
130 Nm or 96 ft/lb
Old 11-18-2014, 05:37 PM   #11
mountainman's Avatar
I have found that most places will tighten them too much unless you are on top of them. I always check mine when I get them home and last year after a new tire change I had to pull one off for something and used a long breaker bar with an extra foot long extension and could not break some of the lugs loose. I went back to the shop and when He asked what he could do for me, I said "how about loosening these lug bolts for me." After looking at me like I was totally helpless he went and got his socket and breaker bar,,,, and then he went back for the bigger breaker bar,,,,, and finally he went back for the air wrench. When he finally got them loose I handed him my torque wrench and told him that from now on when I bring one of my cars in for tires the torque wrench will be on the passenger seat preset to 96 and no more air wrench. Since then no problems and I always check them after a couple hundred miles, and periodically after that. You have to understand that most of these tire shops don't pay employees big bucks and some may not be the sharpest knives in the drawer. On the side of the road with a flat tire is a bad time to find out that someone tightened them down as tight as he could with an air wrench because he didn't want to take a little more time and torque them.
Old 11-18-2014, 08:18 PM   #12
Based on my experience with my cars they always over tighten the lug nuts. I've only seen one shop that actually used a torque wrench. Once they tightened so much that when I tried to loosed the one with a lock I broke the lock socket. This is when I stopped using the locking lug nuts. I've always re-torque my lug nuts since then.
Checking the torque also prevents your rotors from warping.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 11-19-2014, 12:33 PM   #13
Im pretty sure lubing a lug and or thread will lead to overtightening!
LagerAle is offline   Reply With Quote
Old 11-19-2014, 05:41 PM   #14
Nope. The porshe manual has specific instructions for lubricating the lug bolts. Id especially do it if you are driving in the winter with salted roads. Much easier to get the lugs off later.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 11-19-2014, 06:32 PM   #15
Top_Ramen's Avatar
Another good tip: use a (steel)brush to remove any corrosion/oxidation that has built up(if any) on the inside face of your wheel that sits against the hub. If you're specially somewhere that experiences heavy snow during winter. That corrosion/oxidation will prevent you from properly torqueing your wheels on.
'99 Porsche Boxster 986 - weekend car
'04 BMW 645ci e63 - daily driver
'98 BMW 528i e39 - dog carrier
Top_Ramen is offline   Reply With Quote
Old 11-19-2014, 06:36 PM   #16
Top_Ramen's Avatar
Be suuuper careful with lubing lugnuts/ lugbolts.. it tends to lead to over torqueing and snapped studs or bolts.
Old 11-20-2014, 06:05 AM   #17
schnellman's Avatar
Guess I'm anal retentive. When I get back from the tire shop I always loosen every lug nut and then tighten it with the torque wrench. Then, about once a month I check them again with the torque wrench.
Old 11-20-2014, 07:42 AM   #18
Old 11-20-2014, 02:01 PM   #19
lkchris's Avatar
Porsche is somewhat alone in recommending lubrication on wheel bolts.
Mercedes forbids it and BMW does, too.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 11-20-2014, 03:39 PM   #20
I had no idea Porsche recommended this! Once the snow stops falling ive got to resume my fall/winter maintenance.
thanks for the info.
