Old 02-28-2023, 10:55 AM   #21
If you're stuck, it's time to get a smoke machine. I recently go the Autoline Pro and love it. It helped me find a vacuum leak I couldn't find.
Bush Pilot is offline   Reply With Quote
Old 02-28-2023, 11:10 AM   #22
Originally Posted by ellie View Post
What is #20??
My guess is that it is a piece of rubber tubing.
It allows you to connect the hard plastic hose to the hard plastic nipple on the vacuum canister.
If you look at # 19 in the diagram it looks the same.
Then look at the first picture in the first post. You can see #19 just below his thumb.
Bit of rubber tubing connecting a hard three way connector to a one way check valve.
Old 03-05-2025, 10:49 AM   #23
Originally Posted by fornowh03 View Post
Where does #22 Hook up to? Can't seem to find it.
Doesn’t it connect into the intake manifold?
Jbrews is offline   Reply With Quote
