Old 08-25-2014, 06:38 AM   #1
212
986 facelift dash installation problem
I'm in the process of fitting a facelift dash into a non facelift 986 and have encountered a problem with the air distributor ducts. In the non facelift they run across where the glovebox needs to be in the new facelift dash. Has anyone done this upgrade previously?
212 is offline   Reply With Quote
Old 08-25-2014, 12:56 PM   #2
Auf los!'s Avatar
Wow, what a project! You can't be doing it simply to get a glovebox, are you?
Anyway, I don't know the answer to your question, but I know what I would do to try to find someone who has done this swap...I would google for pics of "boxster dashboard," and when I see a pic of a dash all torn apart, look at the page that the pic came from. You might be lucky and find someone who's done the swap and can still be contacted.
Good luck!
2001 Boxster S 6-speed, 2013 Boxster S PDK
Auf los! is offline   Reply With Quote
Old 08-25-2014, 02:19 PM   #3
This was discussed earlier here. Consensus was: it can't be done. The metal crash bar changed to accommodate the glove compartment addition.
2001 Lapis Blue Boxster S Tip (stock), 2001 Guards Red Boxster 5-speed (not very stock)
tightbox is offline   Reply With Quote
Old 08-25-2014, 08:11 PM   #4
If it is just the air ducting getting in the way as you make it sound... I feel like you can build some custom ducting to fix the issue. Im sure it will be time consuming but it shouldnt be too expensive.
Old 08-26-2014, 06:14 AM   #5
212
My car is uk spec and if it's the knee protection bar being referred it's not present on uk cars.
I've acquired a different set of ducts/splitter/outlet vents etc at the breakers from a facelift boxster which allow the ducting to pass around the glovebox and the dash is now pretty much installed with no issues. All fixings etc align perfectly.
Old 08-26-2014, 06:19 AM   #6
212
Good luck!
It's not just to gain a glovebox, it's a much nicer interior, full extended leather with aluminium Tequipment pack. Had to change vents and ducts etc but it's now pretty much sorted.
Old 08-26-2014, 10:05 AM   #7
Coaster's Avatar
Nice, do you have any pictures or a write up?
Coaster is offline   Reply With Quote
