08-12-2014, 09:27 AM
#21
Originally Posted by rfuerst911sc
Porsche designed the IMS bearing.........'nuff said for me. There are better oils than Mobil 1.
Porsche designed the entire car yet you still drive one. Using that same logic, there are better cars than Porsches.
08-12-2014, 10:50 AM
#22
I am my own mechanic....
Given the funds, it's Ferrari or Aston Martin. Maybe MacLaren.
Maserati makes a damn sweet car.
'08 VW Touareg T-3 wife's car
08-12-2014, 11:20 AM
#23
I fix them for a living, and yes there are better cars than this one, just as there are better IMS bearings than the OEM unit (one company has already has over 18,000 replacements installed), and considerably better oils than Mobil 1.
But if you want to continue to drink the Kool Aid, be my guest...........
08-13-2014, 01:59 AM
#24
Motul
Originally Posted by TeamOxford
Motul is a French company and their products are available worldwide. Motul UK is the distributor for the British Isles.
Motul 8100 X-cess 5W-40 is recommended for the M96 engine, and is approved by Porsche. I just switched to this oil from Mobil 1 at my last oil change.
TO
same here, we measured less wear debris in Motul 8100 than M1 so I think its a better lubricant for our Boxsters..
2004 Boxster S
Suzuki Grand Vitara 2.5LV6 / Nissan Elgrand 3.3L V6
Ducati 900SSie / Ducati Pantah 600SL (race bike)
08-13-2014, 07:39 AM
#26
Originally Posted by Timco
What makes mobile 5w50 better than 0w40? Good to know.
Slightly more zinc (about a 100 ppm at the end of the drain interval).
Slightly more phosphorus (about a 100 ppm at the end of the drain interval).
Much better SUS Viscosity at 210 degrees (less shearing of the oil).
08-14-2014, 02:01 AM
#27
Originally Posted by Fatbloke
Its the x-cess that you need. I looked into it last year. I can't remember all the details, could be that the x-clean is for extended drain intervals.... originally recommened for our engines but Boxsters are sports cars with sports engines, trying to squeeze 2 years or 20,000kms out of your oil is false economy in my book. The Motul complies with the Porsche spec and is on the approved oils list for a 2004 2.7.
2004 Boxster S
08-14-2014, 02:54 AM
#28
I will be chnging the oil and filter every 5000 miles as I do with our other vehicles. Just want to make sure I get the correct oil. The X-cess is very slightly cheaper so just wondered if there was much difference in the oil.
www.SNP.org - The Party of Scotland, working for Scotland.
08-14-2014, 05:35 AM
#29
JFP, wasn't there some info. about the zinc content being harmful to the catalytic converters? Seems like we change problems, any insight?
Allen
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
08-14-2014, 08:57 AM
#30
Allen
Yes, zinc is poisonous to catalytic converters, but the case for removing or lowering its content in engine oil is vastly overblown. By EPA law, the OEM manufacturer's are on the hook for the catalytic converters for 80,000 miles if they fail. So they lobbied the EPA to get zinc in the form of ZDDP reduced or even eliminated in engine oils on the basis that doing so would improve emissions by protecting the cats, and the EPA bought it. While it is easy to prove that the zinc kills the cats, the OEM's argument was purely a "straw man" to get out of having to pay for them if they crap out before 80K. If you watch how many cats actually fail early, you would see that not that many do, it is common to see cars in excess of 150K miles and the cats are fine. And of the cats that do fail, reports have noted that many of them failed because of gas additives, not zinc poisoning.
So we get saddled with low ZDDP oils, or oils with other metal salts replacing the ZDDP. Unfortunately, these alternative oil formulations do not demonstrate the same wear reduction characteristics that oils with high levels of ZDDP have, and often break down earlier, requiring shorter oil change intervals.
Based upon what we have seen, I prefer to stay with high ZDDP oils. ZDDP is very hard to beat for wear protection, I am yet to see anyone equal its performance with alternative compounds. And at the end of the day, the cats are a lot easier to replace than rebuilding or replacing an M96/97 engine.
08-14-2014, 09:49 AM
#31
that being the case, what are the oils with highest ZDDP?
08-14-2014, 10:23 AM
#32
Some of the Motul products, Joe Gibbs DT40 or "Hot Rod" oils.
08-14-2014, 10:53 AM
#33
Go back and read post #20. I think all those oils have increased levels. Correct me if I am wrong JFP or anyone else knowledgeable along these lines.
AKL
08-14-2014, 11:36 AM
#34
Motorcycle oils. Diesel oils.
For example, with Mobil products:
0W40
1,000 ppm phos.
1,000 zinc
5W40 Turbo Diesel
1,100
1,200
20W50 V-Twin (motorcycle)
1,600
1,700
12-29-2014, 10:24 AM
#35
Yes i am lame, Yes I know nothing about the Boxster except for I love to drive it. I am new to owning my 97. It is stored from Nov. to April. I am going to change the oil when it comes out of storage. I was going to use Mobile 1 0w40. After reading here. My thoughts are either Mutol 5w40 or Joe Gibb DT40.
The car is a sunday driver. never running with temperature below 32F/0C. Not driven like a race/track car.
I welcome input from one over the other.
1997 Boxster! (Tiptronic)
12-29-2014, 11:21 AM
#36
You should have changed the oil before you put it away.
12-29-2014, 12:05 PM
#37
The Oil had been changed just prior to purchase in Sept. less than 500KM on the car when put away.
Regardless, I'm looking for advice moving forward.
12-30-2014, 06:16 AM
#38
Do that. Or Mobil 5W50. Change every 5,000 miles.
12-30-2014, 06:36 AM
#39
European Spec Mobil 1 0W40 is all I use.
12-30-2014, 01:28 PM
#40
I run Shell Rotella T6 0-40 or 5-40
Depending on the time of year and what is available at the time.
High Zinc and good shear characteristics
Not a recommended oil but oddly loved by many.
Run it in my bikes also.
Oil change intervals every 5 to 6500 KM
