Old 08-02-2014, 04:43 AM   #1
Giller's Avatar
Help with defogging headlight corner trim
Hey all. My headlight corner trim on pass side has condensation showing through, so needs to be removed, cleaned and then resealed? I can't find any instructions on what actually seals in these trim pieces to prevent moisture from getting in. Can anyone help? Want to make sure I have the right product here when I do it. Thanks!
Old 08-02-2014, 05:14 AM   #2
Beginner
Jamesp's Avatar
I took mine apart as the glue holding them together was failing and they had water in them. Getting them off the headlight assembly was tricky, don't break the plastic tabs, and on mine there was a plastic spin rivet to be removed. I got them apart without damage, cleaned them, and used clear silicone adhesive to glue them back together. Go easy on the silicone, it does not take much.
2003 S manual
Old 08-02-2014, 07:20 AM   #3
98 Arctic silver 986
tommy583's Avatar
I had my new (like a month old) clear corner trim fog up. I just drilled two small holes in the back side of it. One on the bottom and one in the back. If it does fog now, it clears up very quickly.
Old 08-02-2014, 05:50 PM   #4
M31
M31's Avatar
This seems to be a common problem with a lot of us...will try these suggestions!
M31 is offline   Reply With Quote
Old 08-03-2014, 12:44 PM   #5
Bruce Wayne's Avatar
looks like you have a bit of water in there !
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 08-14-2014, 09:17 AM   #6
Giller's Avatar
This works nicely! Took a few days for the water to slowly seep out - but a week later it's nice and clear with no water. Thanks for the idea. Two small holes was all it took.
Old 08-14-2014, 01:20 PM   #7
tommy583's Avatar
Glad I was able to help
