Old 07-17-2014, 04:21 AM   #1
Swhitcomb's Avatar
Help! Code p0343
Out of nowhere today on my way to work, my car started miss firing and died. I limped it back home. Running really bad. Sounding like an air cooled VW bad. I pulled the codes and it's P0343. Also miss firing on all cylinders. I'm reading that it could be as simple as a faulty electrical connection. Please tell me that the IMS couldn't cause such a fault. Where do I begin in diagnosing it. I don't even know where to find it.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Swhitcomb is offline   Reply With Quote
Old 07-17-2014, 05:06 AM   #2
P0343 is the Cam Position Sensor (Bank 1) above signal limit.
Sent you a PM.
Regards,
paul...
paulv is offline   Reply With Quote
Old 07-18-2014, 03:32 PM   #3
Swhitcomb's Avatar
Ok, pulled the connector. There is 12v running down the signal wire with the key on. So now all I need to know is, how this wire runs through the firewall and where it plugs into the DME.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
