Old 07-11-2014, 09:44 PM   #1
[QUOTE=dghii;409639]
2. The b pillar switch goes just in front of the defroster connector. There should be a 8mm bolt that tightens the switch assembly to the frame. I'll try to get a pic.
DO NOT OPERATE TOP WITHOUT THE B-PILLAR SWITCH IN POSITION as you can over rotate your transmissions and get things all out of whack (ask me how I know). Your top will not know it is up without a signal from the B pillar.
QUOTE]
I hope I didn't screw things up too bad. I have been operating the clamshell only... kind of a semi-automatic mode...by pushing the dash button and holding the microswitch down manually near the end of the close cycle (front pushrods are not connected yet). I initially synched the transmissions, but a couple of times I heard a pop from one of the transmissions when I let the motor run a little too long. I'm assuming the cable simply popped or skipped over the plastic gear, and that I didn't break the gear itself. I will disassemble and inspect and resynch the transmissions and hopefully figure out how the microswitch gets mounted and try it again.
Paul Ri-Chard
Paul Ri-Chard is offline   Reply With Quote
Old 07-11-2014, 11:29 PM   #2
Check out this link as it has pictures
and is probably clearer than the description I gave. The springs may need to be rotated 180 degrees in their vertical axis...not north to south if that makes sense.
Convertible Top Cable Falling Outside Guide Channel DIY (VERY LONG) *PIC*
papasmurf is offline   Reply With Quote
Old 07-12-2014, 05:07 PM   #3
[QUOTE=Paul Ri-Chard;409651]
QUOTE]
I'm glad you had the push rods disconnected! Take your time and get the b-pillar switch connected and you'll be fine. I'm not sure why your installer would have moved or disconnected the switch.
Tags
convertible top , microswitch location , rear weatherseal
