Old 07-06-2014, 08:47 AM   #1
Hard top set up
Hey guys,
I just acquired a hard top for my non hard top '99.
Can someone help me out on exactly what I need to buy to install it?
Channel locks or whatever theyre called? Part numbers? Cheap place to buy?
Im not sure how to set it up so thinking on bringing it to Porsche to set up, any other suggestions?
Is this the kit I need?
1997 2004 Porsche Boxster Hardtop Hard Top Install Kit | eBay
Thanks guys
evomind is offline   Reply With Quote
Old 07-06-2014, 09:18 AM   #2
KevinH1990's Avatar
Pelican Technical Article: Installing the Boxster Hardtop and Installation Kit - 986 / 987
Old 07-06-2014, 09:31 AM   #3
Joe B's Avatar
Originally Posted by evomind View Post
Yes, that is all you need to install the top. You may also want the 3 plastic covers that go over the latches, if your hard top didn't come with them. Be sure to read up on how to install the spin locks and shoulder bolts (search here and on Google). They can be quite fiddly to install.
I love my hard top :dance:!
Old 07-06-2014, 10:38 AM   #4
Porsche9's Avatar
This is usually he one plastic cover that is missing. It covers the front roof top latch. The two on the side are usually still on the top. Good luck.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 07-07-2014, 02:47 PM   #5
Thanks guys,
Do I need that long "T" shaped hex wrench tool or whatever it is, or can I just use an allen wrench or something?
Im not as concerned abt the interior trim pieces just concerned with getting the top on.
Old 07-07-2014, 04:57 PM   #6
Joe B's Avatar
I happened to already have the long t-handle allen wrench. It might be possible to install and tighten the shoulder bolts without it, but as I remember, the long wrench made it much easier. You don't want to drop a shoulder bolt! This post says the wrench needs to be at least 5" long.
http://memories.ppbb.com/board/museum/te-marer.htm
Old 07-07-2014, 10:22 PM   #7
Now once I get the spin locks in do I just drop the top in and it latches in the front and youre done?
Old 07-08-2014, 07:00 AM   #8
Joe B's Avatar
Well, yes, it latches in the front. And of course as long as you are going to all the trouble to put in the spin locks, you may as well latch it back there too . You may also find the need to fine tune the fit, which is done at the 2 plates at the back under the plastic covers, where it latches. Do a search; there's a lot out there (Google it too).
