07-04-2014, 08:43 AM
#1
Does your 986 smoke i the morning.
Every morning when I start my 2001 base it spews out smoke .....looks like the bat mobile in hot pursuit for a few moments....then it is fine the rest of the day. Is this characteristic of 986 Boxsters?
thanks
2001 Forest Green Metallic Boxster with Porsche Sport Exhaust.
07-04-2014, 08:58 AM
#2
No, not normal.
That is more characteristic of a Boxster whose air-oil separator is preparing to fail.
07-04-2014, 08:59 AM
#3
Mine does not. It's a 2000 base.
Rick
07-04-2014, 09:26 AM
#4
Perhaps I have a slow gas drip from my fuel injectors. It accumulates in the morning, is burned off then is fine during stops and starts the remainder of the day.
07-04-2014, 09:43 AM
#5
No and your last post describes a failing AOS.
07-04-2014, 10:16 AM
#6
OK, interesting, makes more sense..I'll check into it. thanks
07-04-2014, 10:28 AM
#7
Sounds more like you are not bringing the car up to running temp before you park it. Have you been?
:ah:
07-04-2014, 11:08 AM
#8
Sometimes, I'll see if that makes a difference. Thanks!
07-04-2014, 05:37 PM
#9
If it's had morning sex, then yes, she smokes.
I digress. Apologies.
Serious note: Yes...clear sign of AOS. Try this....while running, take the oil fill cap off and place your hand over the opening. If there is a very strong pull, that is another sign of a failing AOS. A working AOS should have a very mild/gentle pull.
Current: 981 Cayman
Former: '02 BS and '08 C
07-04-2014, 05:52 PM
#10
Thanks! Will do!
07-04-2014, 07:05 PM
#11
i thought this WAS NORMAL. there are other post regarding this as well. mine blows a puff of white smoke. on other posts, many others experience it too and we just all assumed it was normal. no cel.
-Tuan
tuanle16@juno.com
07-04-2014, 07:06 PM
#12
every now and again it will do it but not very often
07-05-2014, 06:40 PM
#13
I am my own mechanic....
This. On a damp or cool morning maybe white smoke. After an oil change if a bit high and some spirited driving, a bit o smoke. New AOS helped.
'08 VW Touareg T-3 wife's car
07-05-2014, 08:53 PM
#14
My old boxster did, and it had a new AOS also, my new car does not though? So ummm yeah it is odd, but i do not think it is AOS as the old car had the AOS done within the last 4k miles.
07-06-2014, 03:27 AM
#15
WALDMEISTER
A few seconds white smoke on start up = the so called "Boxster fart" (nothing to worry about, if it only happens occasionally)
Gute Fahrt!
07-06-2014, 06:56 AM
#16
If I drive mine only a very short distance, like into the driveway to wash it and then back to the garage I may get a little puff on startup. Otherwise I get none.
07-06-2014, 09:44 AM
#17
Mine has done it a couple of times when it wasn't sitting on level ground.
07-06-2014, 09:09 PM
#18
I find if I let the car idle for a minute or two after a spirited ride , I don't get smoke the next day and I also have a new AOS .
07-06-2014, 09:37 PM
#19
No
I have had my Boxster 14 months and it has smoked 3 or 4 times in that entire time. As a rule it never smokes on startup. I hate the way they sound on startup however...like a worn out 70's era motorcycle...but every Porsche I have ever heard sounds that way.
