Old 07-03-2014, 06:38 PM   #1
Pdwight's Avatar
Got my Secondary Cat pipes installed today.
Was it a bear...yes at times because I had not done this before. I spent 4 hours doing the drivers side first.....quite a bit of time talking about it's "Mother"
If you decide to do this make sure you get the pipe in place and attach the end to the muffler coupler first....I mean first or you will never get it to go together. The angle is so great you cannot pull the pipe back far enough to slip it into the coupler if it is bolted to the flange first. Bolt up to the muffler and leave the clamps loose, then bolt up the triangle flange to the cats and tighten, then go back and tighten up the couplers.
After I completed the job, cleaned all my tools and put them away I took it for a drive. The sound is a good bit deeper and meaner when you are at 6K , the transition to idle where you always get a bit of drone is deeper and better.
It revs up noticeably faster and I can tell a slight improvement in power. The pipes are huge compared to the pipes on the secondary cats. I could not believe how much the secondary Cats and heat shields weighed.
All in all this was money well spent IMHO as they still have the kit for $150 for members of this board.
Old 07-03-2014, 07:32 PM   #2
myn8m3is8ndy's Avatar
can i get a link to this kit??
myn8m3is8ndy is offline   Reply With Quote
Old 07-03-2014, 08:02 PM   #3
Pdwight's Avatar
Message this member
delubozparts
they only check messages once per day...got here fast and great quality
Old 07-03-2014, 10:44 PM   #4
I'm planning to get my bypass pipes and Circuit Werkes exhaust installed next week. Cant wait :dance:
2000 Boxster S (986)
De-snorkeled withK&N Cold Air intake
Short Shifter 14mm spacers F&B
Secondary Cat delete
Top Speed Test pipes and Exhaust
NJBoxster2000 is offline   Reply With Quote
Old 07-04-2014, 04:39 AM   #5
Pdwight's Avatar
You can do it yourself
Just take your time and use Kroil or PB Blaster on the bolts about an hour before you start the disassembly
Old 07-04-2014, 11:07 AM   #6
rdass623's Avatar
it may also be prudent to order new exhaust clamps for the install. the amount of corrosion on the old ones was bad. also if I were to do the job again, I would also pull the exhaust manifolds. the nuts and bolts on the flange between the manifold and secondary cat pipes were so corroded they needed to be cut off, which was difficult on ramps to say the least.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 07-06-2014, 01:11 PM   #7
Pdwight's Avatar
Deterioration of hardware
I keep reading that people have to get theirs torched off ?
The bolts obviously had been hot, you can tell but a gear wrench and a slight spray of oil and all mine came right our...the clamps at the rear showed no sign of corrosion and came off easily....still shiny gold colored plating on the hardware.
Old 07-16-2014, 03:04 PM   #8
Changed mine to Febspeed years ago and it ws not an issue...no rusted bolts or clamps and process went pretty easy. Sound great with my PSE modified muffler.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
