Old 06-24-2014, 12:27 AM   #1
Code P0410
Hi guys,
My car has been giving me code P0410 every 150 miles after I reset the code. From what I have read, the two codes P0410 and P1411 go together for both banks, amd the usual suspects are the valves, vacuum hoses, air pump, or vacuum reservoir. However, my car has only been giving me only code P0410 consistently, which I believe is not common when these things happen. I'm going take a look at the secondary air injection system, check some vslves and hoses. I also plan to swap the O2 sensors between bank 1 amd 2 to see if the problem follows. Any ideas, suggestions, or opinions?
hancock1701 is offline   Reply With Quote
Old 06-24-2014, 01:12 AM   #2
Top_Ramen's Avatar
https://sites.google.com/site/mikefocke2/checkenginelightcausedbymassairflowsensor
'99 Porsche Boxster 986 - weekend car
'04 BMW 645ci e63 - daily driver
'98 BMW 528i e39 - dog carrier
Top_Ramen is offline   Reply With Quote
Old 06-24-2014, 08:11 AM   #3
Chuck W.'s Avatar
About two years ago my Boxster began throwing different codes. I also had a flat spot at about 3300 RPMs. After searching the forums I determined it was the MAF. It appears that this unit will cause various codes. Looking at "all mota" link, this is one possibility on your issue.
1995 Porsche C4 Cab
Old 06-24-2014, 12:32 PM   #4
I am my own mechanic....
Timco's Avatar
Porsche P0410 OBD/DLC Error Code - Secondary Air Injection System
'08 VW Touareg T-3 wife's car
Old 06-24-2014, 07:13 PM   #5
Jager's Avatar
Here was my fix:
http://986forum.com/forums/general-discussions/49666-p0410-secondary-air-injection-system-cylinders-1-%96-3-a.html
Did you do a search on this forum?
Jäger
300K Mile Club
Old 06-24-2014, 10:08 PM   #6
I did search the forum, but somehow I was focusing on the P0410 P1411 threads. How labor intensive was your fix? You took both the exhaust headers off, right? I don't have a Durametric to check, but I hope my problem is the same as yours, and I will probably do this repair soon. Thank you for the thread!
Old 06-25-2014, 10:36 AM   #7
Mine started with only the 410 and then I later got both. Mine goes away when the weather is warmer, the system is not checked in warm weather. I have choosen not to chase this issue with the assumption/understanding it is SAI related and more trouble than what it is worth.
runjmc2 is offline   Reply With Quote
Old 06-25-2014, 08:46 PM   #8
Jager's Avatar
Yes I took off both sides to do the job. Just spray some PB Blaster or Liquid Wrench on the bolts and let them sit for an hour or so. I recommend getting new manifold bolts, gaskets, and anti-seize compound for the new bolt threads.
Jäger
300K Mile Club
Old 06-25-2014, 08:50 PM   #9
Timco's Avatar
Can't the SAI be flashed and deleted?
Old 06-25-2014, 09:06 PM   #10
Jager's Avatar
But then hancock1701 would be polluting more than the car was designed for. And since he lives in southern California, if he got caught, he loses his first born.
Jäger
300K Mile Club
Old 06-26-2014, 03:01 PM   #11
The only things that I'm worried about are the cat converters getting ruined and me buying expensive OEM cats or not being able to register the car.
Jager, did you get the bolts from a local hardware store? I checked ******************************************** diagram and it says the bolts are M8x28, I assume the pitch is 1.25?
Old 06-26-2014, 05:55 PM   #12
Jager's Avatar
No, I ordered mine from German Part and Restoration... My local Porsche parts supplier. The size you list looks correct.
Jäger
300K Mile Club
