Thread: Code P0410
Old 06-23-2014, 11:27 PM   #1
hancock1701
Code P0410
Hi guys,
My car has been giving me code P0410 every 150 miles after I reset the code. From what I have read, the two codes P0410 and P1411 go together for both banks, amd the usual suspects are the valves, vacuum hoses, air pump, or vacuum reservoir. However, my car has only been giving me only code P0410 consistently, which I believe is not common when these things happen. I'm going take a look at the secondary air injection system, check some vslves and hoses. I also plan to swap the O2 sensors between bank 1 amd 2 to see if the problem follows. Any ideas, suggestions, or opinions?
hancock1701 is offline   Reply With Quote
