Old 06-13-2014, 08:18 AM   #1
Sloppy Shifter
Thanks for the replies concerning the short shifter I am going to drive a friends and see what I think. In the meantime....does anyone have a fix for the sloppy play in my current shifter?
ronf0928 is offline   Reply With Quote
Old 06-13-2014, 01:18 PM   #2
jtmarlinceo's Avatar
I would replace it with an aftermarket shortshifter.
It's night and day and the sloppiness is gone.
_______________________________________________
2008 Porsche 911
2015 BMW M6
2006 BMW M3
jtmarlinceo is offline   Reply With Quote
Old 06-13-2014, 01:23 PM   #3
Pull up the leather surround and have a look and see if the PO put some change in the ash tray and where it has migrated. Also look for loose connections.
Old 06-13-2014, 05:00 PM   #4
The only fix is to replace the worn bushings. Unfortunately, no one (including Porsche) sells just the replacement bushings. Hence, most people replace with an aftermarket short shifter or an OEM shifter (986 standard throw or 997 shorter throw).
Old 06-13-2014, 06:46 PM   #5
ELoomis's Avatar
I replaced mine with a 997 shifter and really like it. Mine was sloppy too 2001 base with 87000.
ELoomis is offline   Reply With Quote
Old 06-14-2014, 03:43 AM   #6
Nimbus117's Avatar
My shifter was really sloppy - right up until the ball joint at it's base failed and I had to drive home stuck in 3rd. Have a look at this thread, was $15 for the new part and the shifter isn't sloppy anymore:
http://986forum.com/forums/general-discussions/16924-shift-linkage-broken.html
2003 Boxster 2.7L
2010 Civic Type R
Old 06-14-2014, 07:56 AM   #7
Chuck W.'s Avatar
Sunset Porsche sells that part for $18.29. If you're going to go to the trouble of replacing the shift cable fastener I would also do the shift cable end (Part No. 996.424.145.01). That piece is $14.67. With shipping, both pieces were $39.16.
1995 Porsche C4 Cab
