Old 06-13-2014, 01:40 AM   #1
uhhu's Avatar
Shaky n/s mirror
Hi all,
I have searched for this - but no results showed.
My wind mirror is shaking like crazy when I'm driving, the faster I go the worse it gets. I like to drive fast, so I would like to get this fixed.
The actual casing is fine, and the mirror moves fine with the electrics. So it's just loose I reckon.
Can anyone point me in the right direction as how to fix this?
Whether it can be tightened up, should the mirror be removed then put back in?
If I take it off, do i need to buy anything to put it back in, etc.?
Any help or pointing in the right direction would be great.
Cheers
uhhu is offline   Reply With Quote
Old 06-13-2014, 02:17 AM   #2
Sounds like something either popped apart or broke on the inside.
You will need to disassemble it to repair. Below is a link that shows some pictures of the inside of the mirror and how to disassemble. The link is for a 997 mirror conversion, but it should give you a good idea of what needs to be done.
Installing 997 Mirrors to 986 Mounts
Old 06-20-2014, 11:28 AM   #3
loose mirror
I had the same problem I took mirror off did not see any adjusting screws for the case, there are two rubber inserts I thought perhaps it was behind them but not the case they just act like shock absorbers, I did not want to take the mirror off so I did the unthinkable that's right I superglued the case so it did not wabble. You can't tell that I did it, but don't tell anyone!
Wild Bill is offline   Reply With Quote
