Old 03-03-2006, 10:58 AM   #1
bmussatti
Guest
Posts: n/a
Weltmeister Wheel Spacers
I read this today regarding wheel spacers, and thought I would share with the forum:
Fits all 5-bolt Porsche. Per pair.
Weltmeister engineered Turbo Star spacers are 40% lighter than heavy solid spacers and over 10% lighter than Factory spacers (they also cost 25% to 50% less). Computer tests show Turbo Star spacer design is safe against deformation at greater than 7g cornering load! These strong 6061-T6 aluminum spacers come in three widths and require longer wheel studs. 21mm spacers require 66mm wheel studs; 27mm spacers require 72mm studs; 54mm spacers require 100mm studs.
Old 03-03-2006, 12:08 PM   #2
Any idea how much the spacers run? Are wheel studs hard to replace? Seems like you would need some special tools or something..
http://static.flickr.com/108/315105667_db319d2142.jpg
2001 Lapis Blue 986
ephidaboost is offline   Reply With Quote
Old 03-03-2006, 12:13 PM   #3
bmussatti
Guest
Posts: n/a
ephidaboost, go to www.********************************************************************.com.
They have 'em!
Old 03-03-2006, 12:23 PM   #4
bmussatti
Guest
Posts: n/a
Here is what they look like:
Old 03-03-2006, 02:01 PM   #5
bmussatti
Guest
Posts: n/a
ephidaboost, I think the term "studs" refers to wheel bolts??
Old 03-03-2006, 02:10 PM   #6
Nah, the studs are the actual bolts that the lug nuts fit onto. They're not hard to replace but you do have to press them in and out. I don't know, probably something you'd want the wheel shop to do.
As for these spacers, I'd be a little worried about the decreased surface area perhaps.
2005 Seal Grey Boxster S
987 Amberectomy
eslai is offline   Reply With Quote
Old 03-03-2006, 02:25 PM   #7
actually, if you look at the back of a Porsche wheel, it looks like the weltmeister spacers. the surface area of the spacer is the same as that of the wheel's mating surface.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 03-03-2006, 03:04 PM   #8
True, but the spacer's meant to act as an extension of the hub, not an extension of the wheel, if you get my meaning. I'm truly not sure how much it matters though.
987 Amberectomy
