Old 03-03-2006, 12:08 PM   #2
ephidaboost
Originally Posted by bmussatti
I read this today regarding wheel spacers, and thought I would share with the forum:
Fits all 5-bolt Porsche. Per pair.
Weltmeister engineered Turbo Star spacers are 40% lighter than heavy solid spacers and over 10% lighter than Factory spacers (they also cost 25% to 50% less). Computer tests show Turbo Star spacer design is safe against deformation at greater than 7g cornering load! These strong 6061-T6 aluminum spacers come in three widths and require longer wheel studs. 21mm spacers require 66mm wheel studs; 27mm spacers require 72mm studs; 54mm spacers require 100mm studs.
Any idea how much the spacers run? Are wheel studs hard to replace? Seems like you would need some special tools or something..
http://static.flickr.com/108/315105667_db319d2142.jpg
2001 Lapis Blue 986
ephidaboost is offline   Reply With Quote
